Muddy Alternator - JeepForum.com
post #1 of 6 Old 06-03-2002, 03:05 PM Thread Starter
BigYella
Muddy Alternator
Hey all. Went mudding yesterday and after a little break my Jeep wouldn't restart. I got a jump and made my way on the hour drive home. Once there, I shut down and tried to restart- on go- battery dead.
The engine was pretty mud caked, including the alternator. I've read that a good cleaning will allow it to work again. Anyone had this experience or have any suggestions? Worst case is I figure I'm replacing it this weekend.
BigYella is offline
post #2 of 6 Old 06-04-2002, 08:51 AM
Sean00TJ
Your alternator is dead. If the contacts/copper get encrusted and/or too wet to the point where they get surface corrosion, that's the end of your alternator (unless you rebuild/clean it).
You can clean your engine compartment CAREFULLY with a hose. The trick is to do it with the engine WARM, not hot. I typically hose out the chunks, avoiding the more tender electrical stuff. Then, I'll literally wash the engine compartment quickly with soap/sponge and lightly hose it out. Then I immeadiately run the engine and let it idle for 10 minuted to dry itself off.
_ _ ___________________________ _ _
00 TJ BDS lift, 33" BFG MTs, locked
Sean00TJ is offline
post #3 of 6 Old 06-04-2002, 08:52 AM
cygnus3978
cygnus3978's Avatar
I suggest having the alt rebuilt for you. Cheaper than a new alternator, especially if you want to upto a high output alt.
'97 TJ SE...yeah yeah I know, it's a 4 banger.
2.5L HIGH OUTPUT BABY!!!
cygnus3978 is offline
post #4 of 6 Old 06-04-2002, 10:18 AM
Sean00TJ
Now that you've seen how MUD KILLS, try a tactis I've been using for a few months now- driving SLOWLY through mud! It works wonders, keeps any mud under the fender where I can get it out. No more mud sprayed hoods!
Sean00TJ is offline
post #5 of 6 Old 06-04-2002, 05:49 PM
JeepinAmerica.com
Yeah that’s the benefit with lockers. You rely more on traction than momentum.
01 Flatfender Sahara.
1 ton axles, full width
Mods listed on my site
Tow vehicle: 01 F350 Dully, turbo deisel, crew cab,
JeepinAmerica.com is offline
post #6 of 6 Old 06-04-2002, 08:21 PM
tjistheway
you guys are going to say im CRAZY but this works. i have done it many times on my tracker , my tj is to pretty to wheel and besides it IS a dodge and you all know what that means whether you want to admit it or not. but any way get your engine started and pour a large glass of water into you alternater and then hit it with somthing a few times and it WILL charge again.dont laugh because i KNOW it works. and for the going slow ill through the mud ill do that when i get old or grow up , which will never happen. anything that breaks can be replaced but not the good times of hauling a## through the mud. so come on guys let me here your so called SMART remarks
tjistheway is offline
alternator
JK Muddy dawnskaybug JK Wrangler Technical Forum 17 06-07-2007 12:14 AM
Muddy top won't come clean RedWrangler04 TJ Wrangler Technical Forum 8 12-03-2006 04:03 AM
Had it one week... MUDDY AK_Jeep YJ Wrangler Technical Forum 23 05-12-2006 02:34 PM
Got it muddy! rhelton04 TJ Wrangler Technical Forum 21 02-26-2004 06:01 PM
Got my feet wet (and very muddy!) TFS TJ Wrangler Technical Forum 4 09-07-2002 05:58 AM
