Mud/ Water proofing the Tranny? - JeepForum.com
post #1 of 9 Old 04-09-2013, 11:24 AM Thread Starter
TJ_Life
ive had to replace 2 clutches in the last 5 months because mud and water is getting into the transmission and tearing everything up... is there any way to prevent this? there was water inside the transmission also
TJ_Life is offline
post #2 of 9 Old 04-09-2013, 11:26 AM
freeskier93
Stop pressing the clutch when it is submerged in mud/water.
freeskier93 is offline
post #3 of 9 Old 04-09-2013, 11:40 AM
idiot magnet
X2
Extend your breather lines to the top of your engine bay. There are write ups for modifying the little vent on top of your transmission.
idiot magnet is offline
post #4 of 9 Old 04-09-2013, 11:44 AM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
avoid mud and water all together, it only causes trouble.
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #5 of 9 Old 04-09-2013, 12:36 PM
gebirgziege
This.
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #6 of 9 Old 04-09-2013, 12:39 PM
Necko2529
About the only way to make it live longer if you play in mud. Pick a gear and stick with it.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #7 of 9 Old 04-09-2013, 12:42 PM
Necko2529
And this will help your whole Jeep live a longer and healthier life.
post #8 of 9 Old 04-09-2013, 12:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep stepping down on the clutch pedal when you're in deep soupy mud only allows the mud to flow in between the clutch disk, pressure plate, and flywheel surface. And no, there is no way to prevent that from happening other than to avoid stepping on the clutch pedal when the clutch/tranny is in deep mud or muddy water.
Stay in 1st gear & if you get stuck & the engine is about to die, don't step on the clutch pedal to avoid killing the engine. Let the engine die in other words. Then re-start the engine in 1st gear without stepping down on the clutch pedal. That will of course mean you will have had to already performed the clutch interlock bypass that will allow the engine to be started without first stepping on the clutch pedal. Starting the engine in gear without first stepping on the clutch won't hurt anything.
Getting
Jerry Bransford is online now
post #9 of 9 Old 04-09-2013, 12:50 PM
frenchy206
^ This
03 TJ Rubicon
frenchy206 is offline
clutch , tj , transmission
