Mucket Seal part number question (rubber part on door surrounds)
#1 | |
99 TJ sport.
Lost drivers side mucket seal for the door surround (where door surround sits on jeep tub) Found the following "for sure" part numbers for every year but a 99. Will it matter or are 96-07 pretty much the same: seal, mucket 1997 and 98: right hand - 55176524AB left hand - 55176525AB 1999??? right side - 55176722AC <--is this correct left side - 55176723AC <--is this correct 2000 right hand - 55177256AA left hand - 55177257AA
#2 |
I just had to replace mine, the ones for the 99 were more expensive then the ones for 2000 on.
For the 99 original part #s are 55176524AB & 55176525AB this is from the 99 Parts catalog. When I went to the dealer we found they had been superseeded by: 55177256-AB 55177257-AB Sorry, looking at my invoice I can not tell which is left and which is right. Note, the ones for 2000 + were About $10 each, the 99's were $36 each ![]() Jeff
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
#3 |
The odd number is the left side, even is right side.
Too bad stupidity isn't painful. |
#4 |
awesome, thanks!
check these out, think these would work? http://www.jeep4x4center.com/mopar/jeep-unlimited/softtop-hardware.htm look at number #15 Right - Header Top and Side Rail 55176722AC More Information 1999-07 $6.25 Left - Header Top and Side Rail 55176723AC More Information 1999-07 $6.25 |
#5 |
here is from 2000 parts book for those who care
#6 |
i called my local dealer and the part 55177257AB was listed at $27.10 plus tax
#7 |
World Class Painter
I just lost a musket seal or had it stolen and it sucks having to pay that much for another one. They come off way to easy, I may have knocked it off, but I won't be buying another one.
So now when I remove the surrounds I take them off and use the screw to attach it to the surround. I put the screw through the hole in the seal and screw it into the nut from the other side. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
