Movement between steering shaft & steering box. - JeepForum.com
post #1 of 1 Old 07-06-2010, 08:58 PM Thread Starter
melcrim
My steering wheel has been developing quite a bit of play in it, mostly when turning to the right. I've narrowed it down to where the steering shaft slides onto the steering box. I can actually slide the shaft up and down on the steering box about a half inch, even after tightening the bolt around the collar that holds it in place. I'm thinking that IS NOT supposed to be like that, but I'd like to know for sure before I go any further. I've been doing some reading up on this & I see that the steering box can be adjusted, but I'd like to know if there is supposed to be any play where the shaft meets the box. I'm thinking I probably need either a new box or a new shaft but I figure I'd give the box adjusting a try first. The rest of the steering components are fine (TRE's, draglink, steering stabilizer, pitman arm, etc.) Thanks.
melcrim is offline
steering , shaft , steering box , play , replace , replacing , TJ
Movement when steering. INCA TJ Wrangler Technical Forum 5 04-23-2010 10:01 PM
Distributor shaft up and down movement - need help. Justified YJ Wrangler Technical Forum 0 04-17-2010 11:37 PM
Movement in the Steering Shaft sethkins88 TJ Wrangler Technical Forum 0 10-05-2009 07:25 PM
Is the steering shaft needed for power steering conversion? tr196 YJ Wrangler Technical Forum 6 04-27-2009 07:32 PM
lateral axle movement when steering Polaris TJ Wrangler Technical Forum 9 08-20-2006 05:50 PM
