mounting NP231 to 545RFE and need advice - JeepForum.com
post #1 of 3 Old 09-25-2010, 10:38 PM Thread Starter
JAC1502
So my np231 Tcase, which i thought would bolt right up to the 545rfe I am using for my hemi conversions lines up but after tightening down bolts I have a 1/4 gap. The input shaft engages fine and the bolt pattern is correct I think the input retainer seal is the problem and need more taper. Anyone know for sure? see image below.
#1 1997 Jeep TJ HEMI, 6" lift springs, 2" body lift, semi long control arms front and rear, Adjustable front and rear track bars, Slip-Yoke elim, 8.8 locked, 10,000 winch, Tube bumpers and rocker guards, Light bar, Custom swing away tire carrier, CAI, Electric cooling fans, Custom exhaust, Mickey T 35*14.5 on 15*12 wheels #2 2004 Grand Cherokee SE 4.0L, header, full exhaust, CAI, Bored TB, Clarion 10, RC X series 4" + 1, teflon wheels 17s, roof rack, winch, etc.
JAC1502 is offline
post #2 of 3 Old 09-26-2010, 01:03 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
STOP........ there are a couple different output shafts on the 545rfe. hopefully you didnt wrench it down too tight.. you can screw up alot of internal stuff..... you can use the 231.... however you have 2 choices, cut down the output shaft on the transmission or call advance adapters and get a 1/2" spacer plate and new longer case studs. i had to run the spacer when i added the atlas due to the 545rfe output shaft length on my trans, it came from a Ram for reference.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
post #3 of 3 Old 09-26-2010, 03:29 AM Thread Starter
JAC1502
I did notice the length difference and I actually trimmed down the rear output shaft of the trans 16mm.
old shaft sat in 9mm
new shaft protruded 7mm
After I finished and I could not mount easily I noticed my np231 female end seems to have tons of room unless the shaft tapers. Does the opening not run all the way into the case? It does measure much deeper than the length of the output shaft. I kinda feel stuped for spending 2 hours grinding mine down but its clean at least
Using a steel rule I checked around the trans output shaft and unless it tapers up or the rear seal is smaller I cant find the interference.
But I could be hallucinating from frustration.
GP what was your output shaft hitting?
I can almost see a ring around the seal retainer where i first tried to tighten it up and the seal retainer ring was too larger.
GP nice builds by the way and my trans is also suppose to be from an 05 ram 1500
JAC1502 is offline
Aluminum Radiator Mounting Advice?? lilgreenjeepyj YJ Wrangler Technical Forum 3 07-08-2010 10:44 AM
In a bind finally bought a spare-mounting advice for a 36x13.5x15 Irok bobehud YJ Wrangler Technical Forum 9 11-08-2009 07:07 AM
Advice needed on purchase of 4.2L I6/AX15/NP231 zwilder YJ Wrangler Technical Forum 9 03-19-2009 09:07 PM
TJ lower control arm mounting holes augured out…need fix advice vetdezracer TJ Wrangler Technical Forum 11 03-05-2008 01:45 PM
NP231, repair advice theonecsf YJ Wrangler Technical Forum 7 12-07-2006 03:28 PM
