Mounting Hockey Pucks ? - JeepForum.com
post #1 of 8 Old 07-15-2010, 01:22 PM Thread Starter
johnxjeep
I just got my pucks. Now, what is the best and easiest way to mount them ?
I really do not want to drill through my spring plate on my 99 Wrangler. PITA
I am going to install my RC Lift Kit this weekend so my suspension will be apart as I want to do it then.
Thanks.
johnxjeep is offline
post #2 of 8 Old 07-15-2010, 01:24 PM
jeepn012
I didn't have to do it on the front, but on the rear I bought a waterproof epoxy. Just scuff the pucks and clean the spring pad really well.
They have been on for 2 years with 3-4 pretty rough wheelin trips. Haven't fallen off yet.
1990 YJ - 96 to 03 My first. She will be missed.
2004 TJ - 03 to 11. Old Faithful. I will have another TJ one day.
2007 JKU - SOLD
2005 LJ - In the mail, hope I like it. Everybody's doin it, here is the build:
jeepn012 is offline
post #3 of 8 Old 07-15-2010, 02:09 PM
ncbluetj
Same here. I epoxied mine to the spring perch. Has been on there for about 1.5 years w/ lots of wheeling. No signs of coming loose yet.
ncbluetj is offline
post #4 of 8 Old 07-15-2010, 02:24 PM
sgtmajor138
2009 JK Wrangler
I have seen hockey pucks used for a lot of things on a Jeep, but I am not following this one. Are you using them as bumpstops?
sgtmajor138 is offline
post #5 of 8 Old 07-15-2010, 02:35 PM
ncbluetj
Yup. A hockey puck glued to the spring pad makes a great 1" extension for your bump stops. It's a cheap and effective solution.
ncbluetj is offline
post #6 of 8 Old 07-15-2010, 02:39 PM Thread Starter
johnxjeep
Bump Stop Extensions.
I thought it was wierd also. After doing research on here and the internet from different people. The reviews and satisfaction from people who have used them when adding a lift kit convinced me to go ahead and use them as extensions.
post #7 of 8 Old 07-15-2010, 11:32 PM
saxart
I welded a nut to the spring plate (I own my own welder).
Then I drilled a hole through the center of the puck and bolted them down. This is a little more permanent than glueing them on.
I intend to live forever. So far, so good.
'99 Wrangler Sport: 2.5" Old Man Emo lift and shocks, adjustable trackbars, Quick-Disko sway links, rollin on 31" BFG A/Ts
saxart is offline
post #8 of 8 Old 07-15-2010, 11:49 PM
garybattles
Epoxied pucks to the spring perch for front bump stops. As was mentioned earlier, scruff up the perch and the puck. Have had mine on for 2 years.
gmb08
garybattles is offline
lift , tj , wrangler , puck , hockey puck , bump stop , bumpstop , install , installation , advice , help , tips
Hockey Pucks for Bump Stop ? johnxjeep TJ Wrangler Technical Forum 7 07-15-2010 01:33 PM
$90 bumpstops? Or better yet, why not hockey pucks? Bennettj13 TJ Wrangler Technical Forum 13 03-28-2010 08:36 AM
were the heck do i buy hockey pucks?? alex71 TJ Wrangler Technical Forum 15 05-13-2006 02:22 PM
anyone here use hockey pucks for your body lift? rsoffar YJ Wrangler Technical Forum 7 11-20-2005 08:00 AM
hockey pucks asjeep TJ Wrangler Technical Forum 9 06-27-2003 10:49 AM
