Mount a 48'' Hi-Lift jack inside a TJ with a soft top.
| Introducing MONSTALINER UV Permanent DIY Roll On Bed Line | TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series |
#16 | |
I used the muffler clamps as well. I put them higher up on the roll bars so the dog could still jump in and out through the tailgate easily. The highlift is only up there when we are off road and the back seat is out. When there are people in the back seat they would hit their heads so the jack just sits on top of the trunk space behind the roll bar. The muffler clamps seem strong enough. I can stand on top of the jack with out any movement. Also solved the wrench need and made it a little easier by putting lock washers and wing nuts on the muffler clamps to make it a quick removal. The full soft top works just fine with the jack up there as well.
Justin |
#17 |
Thanks to all!!!!
I picked up the clamps yesterday and also grapped some wing nuts for easy access. My Hi-Lift will be delivered tomorrow!!!!! If I can figure out how to post pics I'll get some up this weekend to show you guys.
Do any of you guys lock yours inside the jeep? Thanks |
#18 |
I never lock my jeep because it has a soft top on...all someone has to do is just unzip a zipper and take whatever they want lol. I just lock up valuables in the center console and dash...if you go with just regular nuts instead of the winged ones, nobody will steal it because they'd need a wrench...just my 2 cents
Other Vehicles: 07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs 08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers |
#19 |
Quadratec Exclusive TJ-HLJM - Sport Cage Hi-Lift® Jack Mount for 97-06 Jeep® Wrangler TJ & Unlimited - Quadratec
Quadratec has a sport cage mount |
#20 | ||
and Quote:
#21 |
I have the same mounting location, as the Quadratec clamps but i welded 2 bolts one on either side to the roll bar and i have to take the base off the hilift and put in a an offroad bag, but it looks clean, no clamps to worry about soft top goes down nicely.
Midnight Blue '06 TJ//Dana 44 w/4.56/4" Teraflex w/shrt adj arms, 1" teraflex BL, discos, adj trackbar F+R/SYE, Tom Woods shafts/ARB lockers F+R/Yukon frnt axle w/760/ARB Hi output compressor/ Safari Snorkel/KC 6"+8" trails+fogs lights/Procomp Rockcrawlers/35" BFG MT KM2/Warn winch/steering box, oil pan, trans, bellyup,warn diff skids/diamond plate body armor/Olympic Rocker Guards/Herculined/CB/Amsoil all the way around, and a few more things /l ,[____], l---L-OlllllllO- (_) ) ()_)-o-)_) |
#22 |
No I don't have a steel tuffy box...just use the stock stuff
#23 |
Up out and of the way until needed.
#24 |
#25 | |
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ./ It's a trap!\ . . . . . . . . . . . . . . . . _,,,--~~~~~~~~--,_ . . .\ .________/ . . . . . . . . . . . . . . ,-‘ : : : :::: :::: :: : : : : :Ί ‘-, . . \/. . . . . . . . . . . . . . . . . . . . . . .,-‘ :: : : :::: :::: :::: :::: : : : ‘-, . . . . . . . . . . . . . . . . . . . . . ,-‘ :: ::: :: : : :: :::: :::: :: : : : : :O ‘-, . . . . . . . . . . . . . . . . . . .,-‘ : :: :: :: :: :: : : : : : , : : :Ί :::: :::: ::’; . . . . . . . . . . . . . . . . .,-‘ / / : :: :: :: :: : : :::: :::-, ;; ;; ;; ;; ;; ;; ;\ . . . . . . . . . . . . . . . . /,-‘,’ :: : : : : : : : : :: :: :: : ‘-, ;; ;; ;; ;; ;; ;;| . . . . . . . . . . . . . . /,’,-‘ :: :: :: :: :: :: :: : ::_,-~~,_’-, ;; ;; ;; ;; | . . . . . . . . . . . . _/ :,’ :/ :: :: :: : : :: :: _,-‘/ : ,-‘;’-‘’’’’~-, ;; ;; ;;,’ . . . . . . . . . . . ,-‘ / : : : : : : ,-‘’’ : : :,--‘’ :|| /,-‘-‘--‘’’__,’’’ \ ;; ;,-‘ . . . . . . . . . . . \ :/,, : : : _,-‘ --,,_ : : \ :\ ||/ /,-‘-‘x### ::\ \ ;;/ . . . . . . . . . . . . . . \/ /---‘’’’ : \ #\ : :\ : : \ :\ \| | : (O##Ί : :/ /-‘’ . . . . . . . . . . . . . . . /,’____ : :\ ‘-#\ : \, : :\ :\ \ \ : ‘-,___,-‘,-`-,, . . . . . . . . . . . . . . . ‘ ) : : : :’’’’--,,--,,,,,,― \ \ :: ::--,,_’’-,,’’’― :’- :’-, . . . . . . . . . . . . . .) : : : : : : ,, : ‘’’’~~~~’ \ :: :: :: :’’’’’― :: ,-‘ :,/\ . . . . . . . . . . . . . .\,/ /|\\| | :/ / : : : : : : : ,’-, :: :: :: :: ::,--‘’ :,-‘ \ \ . . . . . . . . . . . . .\\’|\\ \|/ ‘/ / :: :_--,, : , | )’; :: :: :: :,-‘’ : ,-‘ : : :\ \, . . . . . . . . . . ./― :| \ |\ : |/\ :: ::----, :\/ :|/ :: :: ,-‘’ : :,-‘ : : : : : : ‘’-,,_ . . . . . . ..| : : :/ ‘’-(, :: :: :: ‘’’’’~,,,,,’’ :: ,-‘’ : :,-‘ : : : : : : : : :,-‘’’\\ . . . . . ,-‘ : : : | : : ‘’) : : :―’’’’~-,: : ,--‘’’ : :,-‘’ : : : : : : : : : ,-‘ :―’’’’’-,_ . ./ : : : : :’-, :: | :: :: :: _,,-‘’’’― : ,--‘’ : : : : : : : : : : : / : : : : : : :’’-, / : : : : : -, :―’’’’’’’’’’’― : : _,,-~’’ : : : : : : : : : : : : : :| : : : : : : : : : : : : : : : : :―’’~~~~~~’’’ : : : : : : : : : : : : : : : : : : | : : : : : : : : : ![]() |
#26 |
My padding is too thick.
The padding thats around the rollbars seems to be too thick, I can't get the muffler clamps to go around the rollbar with enough tread to put the nuts on.
Any suggestions? I purchased 3'' clamps to see if that would help but not really. Thanks |
#27 | |
Selling your tire carrier?! send me a PM i want it |
#28 |
the padding is not to thick its just hard to get on... its snug
99 TJ 4.0l 5speed, 4 inch suspension 3 inch body, 35 bfg km2 tires |
#29 |
#30 |
2 1/2" clamps fit fine, i had to tighten mine almost all the way down, and used a cut off wheel to cut off the remainder of the thread on the unused side. very clean install
FOR SALE:SOLD 2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
