06-03-2007, 06:26 PM
#1
Will tow
motor noise? with video for sound
my 4cyl motor has been makinga ticking sound for almost a year now (the motor is new just replaced last feb) has less then 40k on it,
details of noise, some times it ticks sometimes it knocks, sometime it makes no noise at all, temp makes no difference, goes up with RPM, sounds like coming from #1 cylinder, no cooling fluid leak, no metal shavings in any fluids, i removed the belt and noise is still there
video
06-04-2007, 03:12 AM
#2
Kind of sounds like a diesel. Whats the whistling sound?
06-04-2007, 06:54 AM
#3
As dumb as this may sound.....try swapping the waterpump!
My 97 made a tick/knock/ping like that for about a year as well after I did a engine swap. Then the waterpump started leaking from the weep hole, so naturally I changed it out. VIOLA the ticking was/is GONE!
I have a Jeep :D
06-04-2007, 08:56 PM
#4
Accident Prone Bonehead
Possibly a loose rocker? I would put a tube up to your ear and use it like a stethoscope to isolate the source.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top. Classic4x4 tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
AtoZ Where Zach makes me toys!
Stu-Offroad, because I don't have a clue, but Stu does!
06-04-2007, 09:13 PM
#5
Use a wrench. Itll rattle your ear drum when your on top of the source.x2 on waterpump. Check valve clearence also.
06-06-2007, 08:58 PM
#6
Will tow
ive tried the stethoscope idea and i know its some where in the front of motor but couldnt narrow it down anymore then that,
and jonny the wistle is from where its in 4lo
06-07-2007, 01:43 AM
#7
Is the four cylinder is engine chain driven like the six? If so you can try removing the drive belt and seeing if it still makes the noise. That would reveal if the noise is from something that is driven by the belt including the water pump as suggested above.
06-07-2007, 02:26 PM
#8
Will tow
if i understand you correctly your saying remove the drive belt, and thus narrowing down if its motor or an external accessory like water pump?
06-07-2007, 02:54 PM
#9
Got it in one! Obviously you will loose power steering so if you drive enter corners slowly, and cooling so don't run it for too long.
06-12-2007, 10:42 AM
#10
Will tow
ok so i removed the belt and started it up, it is comin from the motor, cyl 1 or 2, any more ideas?
06-12-2007, 12:42 PM
#11
Worn crankshaft bearings? Anybody else got other/better ideas?
06-12-2007, 03:54 PM
#12
Well, it sounded like an exhaust leak to me. Not good sound though.
2007 Patriot Limited
2006 Unlimited Rubicon
2006 Commander
2000 TJ Sport
My previous Jeeps
1992 Wrangler S (Ole Yeller)
1985 Cherokee Pioneer
1989 Cherokee Laredo
1995 Cherokee Country
1996 Cherokee Country
1996 Grand Cherokee Laredo
06-12-2007, 03:58 PM
#13
Will tow
how could i check that?
there is a small exhaust leak but that would cause the knocking like that would it?
06-15-2007, 07:37 PM
#14
Will tow
any more options?
06-15-2007, 07:45 PM
#15
If the 2.5 has a timing CHAIN that could be it... I streached a timing chain on my 4.2 several years ago and made a simular noise.
When you listen for the noise in a wrench or crowbar, can you narrow it down to the Valve Cover, Head, Block, or Oil pan?
