Quantcast motor mounts not lining up - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > motor mounts not lining up
Free Shipping on all Engo Winches Continues...starting at Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 07-31-2010, 02:12 PM   #1
nankipoo
Installing 2.5
The mount on the drivers side seems to line up but the one on the other side is way off. I bought this jeep in peices so IDK if I have the right mounts or how they are supposed to look. Ideas sujestions?
The picture of driver side, It will move to line up and the bolt go in but that just makes the other side worse.
The jeep is tj 97 Im betting the motor might be a pre 97 IDK
Lowell
1997 TJ 2.5 to 4.8 Coversion Project
2000 Grand Cherokee WJ v8 4.7
2008 V6 Wrangler unlimited sahara steel blue
nankipoo is offline   Reply With Quote
Old 07-31-2010, 02:58 PM   #2
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
You have an XJ and your in the TJ forum?
GOLENJEEPTJ is offline   Reply With Quote
Old 07-31-2010, 03:00 PM   #3
GOLENJEEPTJ
Your profile shows a JK on the avatar,you list an XJ,and you have a V6?Time to redo your profile for proper forums?
Old 07-31-2010, 03:27 PM   #4
nankipoo
I still have the other jeeps, This is a new project 1997 tj 2.5.
I have been out for a few hours trying to get he mounts to line up. Are 4.0 mounts diffrent than 2.5? These are just what the other guy had so IDK if they are right. I can tell someone had been grinding on the mounts to make them more narrow.
Lowell
Old 07-31-2010, 03:34 PM   #5
nankipoo
Ok I fixed the profile the *j stuff LOL
Lowell
Old 07-31-2010, 03:52 PM   #6
Red_
Are the bolts that hold the trans to the skid loose? It might be causing a bind knocking stuff out of alignment
Red_ is offline   Reply With Quote
Old 07-31-2010, 04:19 PM   #7
nankipoo
trans bolts untouched, might try that tonight.
Lowell
Old 07-31-2010, 04:25 PM   #8
outlawjeeper
You can pull the drivetrain back with a ratcheting strap but the side side to side play is harder to take out. If your doing a conversion than you may need to swap the motor mount brackets.
outlawjeeper is offline   Reply With Quote
Old 07-31-2010, 04:31 PM   #9
nankipoo
What if I end up with it about 1/4" high? The only thing that might do is change the fan spacing right? What I had in mind was if I cant get that last 1" then use a 1/4 adapter plate under the mount.
Lowell
motor mount
Glock Forum
