#1 | |
Motor Mount Body Lift Question:
Im not entirely sure about a few things.
If you put a body lift (lets say 1") and add a 3.5 in suspension lift, what is the reason for the Motor mount lift? Im under the impression that it has something to do with being able to use a greater clearance skid plate and/or lifting the engine back up to the body where it used to be before the 1" body lift. If this is true, and you arent really worried about a different skid plate and just want your 3.5 inch lift, then do you even need a body/motor lift? I know thats a lot and its confusing cause I dont really know how to say it..but help out! Chris ![]()
#2 |
Fish fear me
It's to help with drivetrain angle issues. Lifting the engine helps take a little angle out of the drivetrain.
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#3 |
Jeep
The motor mount lift isn't required with the body lift, but it is suggested, especially with that 3.5" lift, for a few reasons.
1. You don't have to lower the radiator shroud, instead you will raise the motor an inch and it will match the height of the shroud. You also gain an inch in ground to engine clearance. 2. It helps correct the angle in the t-case linkage that the body lift causes. 3. Most importantly, it helps correct driveline angles after a suspension lift is installed. With up to ~2" of lift, it will most likely eliminate any vibes, if there were any to begin with. Anything above 2" really needs a SYE/CV or a t-case drop, regardless of a MML or not. The MML will help, but won't cure the vibes. The MML also allows a tummy tuck (certain vendors require a MML in order for a TT to work).
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#4 | |
#5 | |
Jeep
No matter what size suspension lift you get, the SYE/CV will correct all driveline vibrations... regardless of a BL/MML.
#6 |
ok cool. Im thinking of a MORE motor lift and i dont know who about the body lift. and im gonna stick a 3.5 inch suspension lift. 33 x12.5 Mickey Thompson Baja Claw tires and some 15 inch rims.....gonna be a sweet ride.....
#7 | |
Jeep
#8 |
Cool man, Ill look into it. One more thing! You see those ads for polyeurathane (SP?) suspension part replacements?? What is that for? Does that replace those parts that you have to grease?
#9 | |
Jeep
As for replacing the suspension parts with it, not a good idea. Squeaks and trouble is all you're asking for if you do that.
#10 |
get some MM
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
