More stripped torx bolts? - JeepForum.com
post #1 of 4 Old 05-21-2009, 06:07 AM Thread Starter
Deadhorse
Got some windshield light mounts yesterday and low and behold one bolt on either side of my windshield stripped when I tried to remove them.
Anyone know what the thread is on these and is it something I can pick up at home depot?
Deadhorse is offline
post #2 of 4 Old 05-21-2009, 06:44 AM
Goondock
2010 JK Wrangler
Are you asking about replacements? If so, every time I take one of those damn torx out I replace it with an actual bolt. attached is a picture. I like the look better with bolts as opposed to torx. I originally bough a bunch of torx to replace the ones I stripped before I went to bolts. Got them from Sears Hardware. I will check tonight to see if I still have the item number.
qUittErs nEVeR wIN...
Goondock is offline
post #3 of 4 Old 05-21-2009, 06:49 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
If you took one out just take it to Home Depot and match it up.That's what I did with my bumpers.
TheBoogieman is offline
post #4 of 4 Old 05-21-2009, 06:50 AM
Dean O
Dean O's Avatar
Ah the joy that is jeep ownership. I believe they are 1/4-20. I had to replace two of mine when I put my lights and mirror movers on. Tip for the future. Heat the bolts with a propane torch before trying to break them loose. It'll help break the thread lock put on at the factory and makes your work much easier!
2000 4-dr Sport XJ- RED 3" lift, moabs and 31" MTs
'97 TJ Sport- BLACK-2" lift and 32"s
Dean O is offline
HELP! Stripped torx bolts on window hinge distantdog TJ Wrangler Technical Forum 42 05-11-2011 01:07 PM
Help Please...Stripped Torx bolts in windshield frame. Prryan45 TJ Wrangler Technical Forum 10 09-08-2009 09:04 PM
Stripped Torx Bolts! (removal & replacement?) Bethlehem TJ Wrangler Technical Forum 10 11-01-2008 11:49 PM
solution for stripped torx bolts YJ_95 YJ Wrangler Technical Forum 15 05-26-2008 11:16 AM
Removing stripped Torx bolts voigtrobert TJ Wrangler Technical Forum 2 02-17-2006 11:57 PM
