More Problems with Lift Install - JeepForum.com
post #1 of 12 Old 09-23-2005, 10:57 PM Thread Starter
rjkjoe
Alright, I'm calling it a night for installing my 1 1/4 body lift and 1" BMML. I've got everything in place except I can't get the front mount lined up right (as posted before) and I can't get the passenger side bolt tight underneeth the Jeep because of a bolt in the way that wasn't there when I took the motor mount off to begin with. Now I tried my shifter and it won't stay in 2nd 4th or 6th. What should I do????
rjkjoe is offline
post #2 of 12 Old 09-23-2005, 11:01 PM
AjRagno
Go to bed
I'm sure you'll be fine tomorrow, when you're refreshed.
AjRagno is offline
post #3 of 12 Old 09-24-2005, 12:45 AM
Moab Man
The body lift and motor mount are causing your shifter to hit against the opening in the floor. You will most likely need to cut the hole larger.
Moab Man is offline
post #4 of 12 Old 09-24-2005, 07:10 AM Thread Starter
rjkjoe
Cut what? How do I get the shifter boot off? This is turning into a huge headache. But I guess it'll be worth it when I'm done.
rjkjoe is offline
post #5 of 12 Old 09-24-2005, 07:45 AM
Rocky529
Rocky529's Avatar
Normally you would have to adjust your shifter boot... but because you have a 6 speed (leather shift boot, bag style), I'm assuming your boot isn't catching... does the boot bunch up a lot when you shift into 2 4 or 6? If so move it up an inch... pop the boot off of the bezel on the console and there will be a ring around the shift itself... move that up an inch. If that doesn't help, take the boot off completely and shift... see what it's getting hung up on.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #6 of 12 Old 09-24-2005, 08:40 AM Thread Starter
rjkjoe
The boot is bunching up when trying to shift in 2nd 4th and 6th. How do I remove the shifter bezel?
rjkjoe is offline
post #7 of 12 Old 09-24-2005, 08:44 AM
Rocky529
Rocky529's Avatar
I know on the 5 speed it just pops up with a little force... just put the tip of your fingers around it and pull up... should pop right out.
Rocky529 is offline
post #8 of 12 Old 09-24-2005, 10:03 AM
PDX_XJ
PDX_XJ's Avatar
Get creative and move your console back 1" or so. That's what I did. Works great.
Another alternative is now getting a flat skid.
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline
post #9 of 12 Old 09-24-2005, 10:06 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Moving the console back is probably the best/easiest way to eliminate this problem. Installing a flat skid opens up a whole new can of worms.
Jerry Bransford is online now
post #10 of 12 Old 09-25-2005, 08:21 AM Thread Starter
rjkjoe
Any more suggestions on relocating the shifter. If I take the boot off I can shift through all the gears. Has anyone heated up the shifter stick and bent it foward. I'm thinking this might be the easy solution.
rjkjoe is offline
post #11 of 12 Old 09-25-2005, 09:53 AM
Jerry Bransford
Administrator
Once again, it'd be a whole lot easier to just move the console back an inch as many do. Take it off, redrill the floors in the hole 1" further back and remount it.
One more thing you can try first is to remove the neopreme piece that is at the bottom of the shift lever underneath the shift boot. Pull the shift boot away from its mounting flange by grabbing it at the corner and lifting up. You'll see the neopreme tube underneath that is there only to support the boot... that doesn't really need supporting. That piece of neopreme can restrictsthe shift lever throw a bit after a body lift has been installed so removing it may fix your shifting problem. It can't hurt, I took mine out 7-8 years ago for this reason.
post #12 of 12 Old 09-25-2005, 11:13 AM Thread Starter
rjkjoe
I'd move my console back however there is no room. It extends all the way to the back seat where the floorboard raises and the cup holders are right against that. That's why I'm looking for alternative ideas.
rjkjoe is offline
Lift Install Problems.... Unlimited04 TJ Wrangler Technical Forum 22 04-20-2010 05:43 PM
lift kit install problems... jmkeo74 TJ Wrangler Technical Forum 6 02-23-2008 03:00 PM
Problems with lift install No Fear Jeep TJ Wrangler Technical Forum 3 06-16-2007 02:34 PM
List your problems with lift kit install Snuffster TJ Wrangler Technical Forum 11 09-24-2006 04:44 PM
several problems since my re 4.5 lift install incubus2012 TJ Wrangler Technical Forum 6 05-25-2005 11:06 AM
