Mopar has a new pan for the 42RLE transmission - JeepForum.com
post #1 of 56 Old 08-11-2010, 11:48 AM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I nearly forgot to mention here that I read an announcement a few weeks ago that Mopar released an improved version of the 42RLE transmission pan for the 2006 model year TJ. It holds more ATF for slightly better cooling and it makes it far more difficult for the transmission to suck air on an extremely steep climb. It of course can be installed on earlier TJs that have the 42RLE which started with the 2003 TJ with the 4.0L engine
So if you're in the market for a new pan for your 42RLE automatic transmission or just want the slightly increased capacity, the Jeep dealer can get it for you. I don't have the p/n however, the Jeep dealer's parts department I use to work with is no longer a Jeep dealer.
Unlike the only aftermarket pan for the 42RLE I'm aware of from RockKrawler, the Mopar pan should fit with pretty much any aftermarket skidplate or bellyup skidplate.
Jerry Bransford is offline
post #2 of 56 Old 08-11-2010, 12:01 PM
2006_Sport
Good stuff Jerry. I'll look into it next time I need to change my trans fluid!
2006_Sport is offline
post #3 of 56 Old 08-11-2010, 12:54 PM
robncar
robncar's Avatar
Anyone have this pan? Pic VVV
YourCovers.com 42RLE Transmission Pan
What's strange is that they DO NOT lower the pickup?
Jerry, I've looked all over for the new Mopar pan part number without success. Currently, we overfill by about 1/2 quart (pint) since we had a scary cavitation a couple of years ago.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 56 Old 08-11-2010, 01:28 PM
otisdog
2008 WK
Thanks for the info Jerry.
jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 56 Old 08-11-2010, 01:46 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I just called the dealer to confirm this. I'm having my 42RLE serviced tomorrow & they will install it. The pan is indeed an upgrade with more capacity. The "unofficial" reason for the change is the cavitation we all know as common to the 42RLE...but Jeep will not admit it since it implies recall issues & major safety concerns. You need a new magnet when replacing the 03-05 pan with the 06 pan.
PN's:
Pan: 52852912AC - $17.25
Magnet: 4446728 - $5.78
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 56 Old 08-11-2010, 01:50 PM
2006_Sport
20 some bucks for a new, more effective pan? I'm down.
post #7 of 56 Old 08-11-2010, 01:53 PM
Unlimited04
you have a 2006...you already have it.
Useful Write-Ups:
Funny:
post #8 of 56 Old 08-11-2010, 01:56 PM
2006_Sport
Really? Interesting. Cool with me though.
post #9 of 56 Old 08-11-2010, 02:01 PM
lax22
Great! I'm in Thanks guys for the PN's. Any idea how much more fluid this will hold?
Current Jeeps
04 Rubicon
lax22 is offline
post #10 of 56 Old 08-11-2010, 02:42 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Jerry mentioned it was a new release from Mopar.
It sounds as if none of the factory TJs left the line with this pan installed.
Wheelin98TJ is offline
post #11 of 56 Old 08-11-2010, 02:52 PM
Wheelin98TJ
JEEP FREAK
PN's:
List price is only $9.60 on that tranny pan.
If it was a plastic interior trim piece, it would be $200.
post #12 of 56 Old 08-11-2010, 02:55 PM
undercoverfab
Vendor
undercoverfab's Avatar
I just ordered a pan and magnet from my local dealer for $13.52 out the door. That's really cheap for anything at the dealer!
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #13 of 56 Old 08-11-2010, 02:55 PM
mrbates
RESIDENT METAL
anyone know if this pan would fit with the savvy under armor?
I have a Jeep.
2003 X. 3" SA. Locked D44s F/R. 35" MTR-K's
mrbates is offline
post #14 of 56 Old 08-11-2010, 02:57 PM
robncar
robncar's Avatar
Looks like that pan is for 2007 to 2009 JK's too...
52852912AC $9.60 $0.00 $7.30
Transmission - Transmission components - Trans pan - 42rle
42rle 2007
Trans pan 2008 - 2009
robncar is offline
post #15 of 56 Old 08-11-2010, 03:03 PM
solarpower
PN's:
Hmmm are you sure???
I have a receipt from dealer dated sep 21 2007 for a replacement pan, magnet, and filter.
pan: 52852912AC 7.50
magnet: 446728 2.45
filter: 5282913AB 19.00
I am pretty sure that the capacity is the same. I sure as hell remember it looking identical to my old pan...except for the slight dent I had in mine.
the new magnet is much smaller and the dimple that it sits in is smaller but I thought everything else looked the same.
I think I still have my old one...I'll have to go look.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
42rle , transmission , pan , new
Help. 42rle Transmission Problems P1776 lilcobrar TJ Wrangler Technical Forum 20 07-01-2015 07:24 AM
42RLE Auto Transmission (Regeared 3.73,4.56,now 4.88) JESSETHELJ TJ Wrangler Technical Forum 57 07-21-2011 01:32 PM
Transmission swap NV3550 to 42RLE? djfuzzy TJ Wrangler Technical Forum 21 02-25-2010 11:11 PM
GM V8 swap to jeeps 42RLE transmission straycatboat TJ Wrangler Technical Forum 14 01-25-2010 10:10 AM
Where is the breather for a 42RLE transmission? Windsor TJ Wrangler Technical Forum 2 03-19-2006 10:03 PM
