#1 | |
Monster Frustration!
Hey Guys,
so i am taking apart my NP231 TC to put in the new rear shaft for the new driveshaft. I got the driveshafts off fine, i removed the yokes easily. the rear housing was a pain, but it is now off. I started to remove the 15mm bolts so i could take of the rear part of the TC when I got to a 11mm bolt (or at least i thought it was.) so I ended up rounding it off with the impact wrench and tried for an hour to get vice grips etc on it to make it budge.....no luck. I then used a dremel and cut a big slot in it to try and get a monster screwdriver in there and that didn't work out to well (dumb plan to begin with). so now i am at my wits end with a 10mm round head bolt with a standard head that won't budge. Anyone have any other ideas for removing this little guy??? P.S. I soaked it in PB Blaster for a few hours while doing this. I tried hammering the bolt to loosen it up. I also tried heating it up.
#2 |
I broke my what????
I'm not sure what bolt you are talking about since I have not taken my TC apart. However, I would strongly recommend a bolt-out set. I have a craftsman set and it works GREAT!!! It has saved me several times.
http://www.sears.com/sr/javasr/product.do?cat=Hand+Tools%2C+General+Purpose&pid=0 0952162000&vertical=TOOL&subcat=Bolt-Out%2C+Taps+%26+Dies&BV_UseBVCookie=Yes Hope that helps Mike |
#3 | |
Brake Wizard
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#4 |
Do it right or not at all
![]() Join Date: Jan 2003
About all you can do now if you can't get to it enough to cut the bolthead off is to remove the t-case and then cut the bolt head off. Typically a 12-pt. 10mm socket is used to get that top bolt out if that's the one that got boogered up.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#5 |
If you have a dremel tool and IF there's room you could always try to grind down the sides in an attemp to make a 10mm or so socket fit.
Just a thought... |
#6 | |
Brake Wizard
The reason I was asking if that was the one is I have run across one or two that have a nut on the backside as well as being threaded through the case half. Take the nut off and the bolt comes right out.
#7 |
i didn't see a nut on the back but i think i'll go ahead and try and cut the head of with the dremel and hopefully i cut it flush.
is the TC aluminum? if so it probably wouldn't be a good idea trying to pry the case off if i didn't cut the head completely off right? |
#8 |
Not sure how much room you got, but could you tack weld a nut on to the end of the rounded head?
#9 | |
2001 TJ, 4.0, 2.5" OME, JKS Discos, MM e9000, AtoZ Rockers, Skidrow Oil/Engine, Serveral custom WV pin stripes [URL="http://www.sahdowx.com/gallery/"]http://www.sahdowx.com/gallery/[/URL] |
#10 |
I broke a bolt on my CJ transfer case. Like previously stated, I ground it, pulled the case apart and was left with a nub but not matter what I tried I still couldn't get it off using the nub. I ended up grinding it flat and leaving it out. If you really want a bolt in there and can't get it out, you'll have to drill it and retap it. I just siliconed it up, and tightened the remaining bolts, no leaks. Good luck! It's not as bad as you think.
Definition of Rubicon: A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment. |
#11 | |
yeah i have a little mig i could tack a bolt on there.....i'm a crappy welder though and i once i start welding stuff on the jeep i am scared that i won't stop! ![]() |
#12 |
Forum porn star...I guess
Since you already cut a slit in the bolt head, go to the nearest tool store and buy an impact-driver. This little tool works wonders sometimes.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay..... |
#13 |
strange as it sounds, I had a hell of a time getting my t/c fluid fill plug out. Tried all sorts of things, it wouldnt budge. Last ditch effort I actually tried to TIGHTEN it. Tightening it was all I needed to break the threads loose and then it came out like a charm! Try it!
2002 Wrangler Sport 4.0L 3 Speed Auto DPG Offroad "Ultimate TJ" Old Man Emu lift kit 33x12.50 BFG All Terrains American Racing Diamond Back 15x8" rims 1.25" JKS Body Lift and 1" JKS Budget Motor Mount Lift 4.10 Gears with Alloy USA Grande 35 w/ OX Locker |
#14 |
thanks guys,
i tried that impact driver allready, and i could not tighten the bolt because it was so stripped. i used the grinder and a dremel to take the head off. all good now! thanks again for all the suggestions |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
