Monstaliner: A Full Install Write-Up - Page 33 - JeepForum.com
post #481 of 521 Old 02-11-2012, 06:38 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by JacKedUP4x4 View Post
Those ones snapped so I drilled all 4 out and in just gonna put bigger bolts back in. The one thats stuck is the one holding the seatbelt to the rollbar i just got a blade and plan on cuting it in half then using vice grips to pull the rest out
Or borrow an impact wrench, that worked for us
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #482 of 521 Old 02-11-2012, 07:27 PM
JacKedUP4x4
My friends letting me borrow one. The seatbelt bolt I started to saw through with a hacksaw earlier so I think it will probably just snap if I try to use the impact wrench on that
JacKedUP4x4 is offline
post #483 of 521 Old 02-11-2012, 07:29 PM
JacKedUP4x4
Also that one is stripped
post #484 of 521 Old 02-11-2012, 09:09 PM
PirateQM
1982 CJ7
Read the whole thread... a lot of good tips, thanks!
I plan on doing both interior and exterior to my '82 CJ7... just waiting on two things... the color chips to decide which color (thanks Magnetman for replying to my call the other day and letting me know the chips are a bit behind, completely understand) and the Jeep itself. It's at my brother's in Texas and I can't wait to go down there and bring it back home!
Interior will definitely be black. Leaning towards midnight special on the exterior, but also love all the reds and even the burnt orange. Just want to see them in hand, in the sun, before deciding... I've learned that colors on the computer screen don't always match exactly in person, LoL!
Does anyone know how many gallons for 2 good coats on exterior? I will also be doing the inside of the doors and dash in the exterior color as well.
I can't wait to start this project!
~Semper Paratus~
'97 TJ (Polaris) Long gone, but not forgotten.
'85 CJ7 (LiL Dragon) Hauled away to be scrapped.
'82 CJ7 (Echo)
PirateQM is offline
post #485 of 521 Old 02-11-2012, 11:07 PM
JacKedUP4x4
Can I use a duplicolor engine enamel paint primer to cover the bare metal spots where I sanded too much and where I sanded off rust? Do I have to use a primer if I'm using the chassis saver? Or if I put that down over some spots of bare metal would it work? I wanna make sure I do this the right way so I don't have any problems later on
post #486 of 521 Old 04-01-2012, 02:06 PM
LDJ37
Great tips here, I ordered my kit Friday and plan to paint Easter weekend. I have some questions, sorry if I missed the answers in the thread:
How far up the roll bar did most of y'all go? I plan to go to the edge of the tub. ( I know personal preference, but I am open to suggestions)
How far up the floor boards under the dash?
The wiring running down the drivers side, anything I need to look out for there? I plan to go up over the edge to the soft top retainer ledge.
Did y'all take the door and rear gate receiving latches off? I plan to and paint the bodies of them off the jeep.
The silver device in front of my console, I assume the airbag actuator, is it ok to unbolt and just hang somehow?
This isn't a huge insight or tip but the PO had a CB and some kind of speakers or tool box both bolted through the tub, I am going to CS the area and use short carriage bolts to fill the holes and coat over them. Seems like a nice clean fill.
Thanks for the help, this jeep is new to me by 1 week and I am anxious to get started with its clean up and semi-build.
LJ
LDJ37 is offline
post #487 of 521 Old 04-01-2012, 04:34 PM Thread Starter
LuckRider
LuckRider's Avatar
I just covered the plate that mounts to the tub for the roll bar. I didn't go up it. Some have covered the entire thing, other just go up enough to hide under the covers.
I went all the way to the firewall because, why not?
There really isn't much to worry about there. Just pull it out of the way to get the liner behind it. If you get some liner on it, it doesn't matter because the bundle is wrapped.
Nope, just taped them off.
Just tape around that. You really don't want to mess with airbag stuff. Yes, that is the sensor for the airbag. I believe it works using accelerometer technology.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #488 of 521 Old 04-01-2012, 07:06 PM
LDJ37
Thanks Luck! As usual, helpful. I started the breakdown today, just my driver seat left and I had it out for awhile to start cleaning. I will try to remember to take pics as I go and post.
Thanks again, LJ.
LDJ37 is offline
post #489 of 521 Old 04-01-2012, 09:29 PM Thread Starter
LuckRider
LuckRider's Avatar
No problem. Best of luck with your project. It is always great digging into the new Jeep and making it yours.
Support Our Troops!
JFI Member #7:
post #490 of 521 Old 04-30-2012, 07:13 PM
BAMFpullin719
for anyone who covered their whole jeep in monstaliner, how many gals did you use and how many coats did you apply. i will be spraying it. magnetman you may also be able to answer my question
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #491 of 521 Old 05-04-2012, 08:36 PM Thread Starter
LuckRider
LuckRider's Avatar
Sorry nobody replied to you earlier BAMFpulling719. I used 1 gallon for my TJ.
Support Our Troops!
JFI Member #7:
post #492 of 521 Old 05-10-2012, 06:30 AM
BAMFpullin719
im wondering about coating the exterior of jeep, if one gallon will be enough or if it requires 2
post #493 of 521 Old 05-11-2012, 06:19 PM
Hosep
Day 2 of prepping the inside of the Jeep. Yesterday I took everything out of it. Today I started sanding, and today was the first day I wish I didn't have a white Jeep, hard to see where and how well it is sanded.
My playground
Hosep is offline
post #494 of 521 Old 05-12-2012, 11:23 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Some claim to have done exteriors with 1 gallon, others have used over 1.5 gals
Depends on application method (roll vs spray) and how heavy it goes on
Color choice may also influence amount needed and if you are changing the color of vehicle. Certain colors that do not hide as well going over contrasting original color will need more to cover
Connect with us on:
post #495 of 521 Old 05-12-2012, 11:25 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
White and silver will make you craaaaaazy. This is good scuffing on darker paint
Connect with us on:
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 01:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 12:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
