Monstaliner: A Full Install Write-Up - Page 32 - JeepForum.com
post #466 of 521 Old 01-31-2012, 06:12 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by BJmyTJ View Post
Haha it happens, thanks.
Email or PM me that tracking # info and we'll get it corrected before it travels too far to change
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #467 of 521 Old 01-31-2012, 06:18 PM
JacKedUP4x4
I can foreward it to you send me your email
JacKedUP4x4 is offline
post #468 of 521 Old 01-31-2012, 06:23 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
send it to info@monstaliner.com
Connect with us on:
post #469 of 521 Old 01-31-2012, 07:04 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I can forward it to you send me your email
Got it, will contact UPS in the AM to fix the zip so it does not go to LiveAndLearn
Thanks for the heads up and sorry for the inconvenience and thanks for your business!
Connect with us on:
post #470 of 521 Old 01-31-2012, 07:35 PM
BAMFpullin719
Originally Posted by magnetman View Post
Monstaliner Bloodbath exterior with clear coat on top
god damn that looks great! guessing that was a spray on job? im having my body guy spray my tub at end of the month. any advice when it comes to spraying? im getting the gun thats on the site but anything else?
also running any specials now or soon on the original monstaliner?
thanks magnetman and keep up the good work!
"4 low, 2nd gear, skinny peddle on the right"
bought not built, broke, then rebuilt
you thought you had rust?
BAMFpullin719 is offline
post #471 of 521 Old 01-31-2012, 09:19 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
That Bloodbath was sprayed and the guy said he had never painted anything before but a tractor
If you can justify the extra $29, get the better gun and see the promo link in my sig for the ongoing special
Connect with us on:
post #472 of 521 Old 01-31-2012, 10:09 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Another great looking job
93 Eddie Bauer Bronco, Desert Sand
Connect with us on:
post #473 of 521 Old 02-11-2012, 03:59 PM
JacKedUP4x4
So far I have most of the back sanded everything out except the front seats cause of course the torx bolts are being a *****. I got one of the brackets the back seat sits in out both those bolts snapped on the other side one is half way stuck and spinning and the other will probably snap like the rest and one of my rear seatbelts is out the other one is of course stripped and part way out. So far this has been a pain in the *** but hopefully I'll have everything out tonight and sanded so I can roll it all on tomorrow
post #474 of 521 Old 02-11-2012, 04:43 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I had some minor issues in one of the jeeps we did in our warehouse. Used lots of WD40 and we wound up borrowing an impact wrench for a few of the front seat bolts and the seat belt bolts
Also: China made torx tips are a waste of time! Buy AMERICAN!
Connect with us on:
post #475 of 521 Old 02-11-2012, 05:21 PM
JacKedUP4x4
Idk what I'm going to do for the stripped one in the back.. but I drilled the other holes out and in just going to put bigger bolts in if I even put the back seat in. Just have the 2 torx bolts to get out on the front seat. Then sand the rest. For the chassis saver how many coats do you reccomend I put on, and does the bedliner just get rolled on over top of it?
post #476 of 521 Old 02-11-2012, 05:37 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
1 coat of CS is enough in the tub assuming you going over old scuffed paint.
On rusted areas you can spot prime these spots first and then do whole tub with 1 coat so the rusted spots will now have 2 coats
Yes put ML direct over CS within 24 hrs with no addit scuffing needed
With stripped bolt, can you see and get to where it comes out under tub?
Connect with us on:
post #477 of 521 Old 02-11-2012, 06:18 PM
BEETROOT
I bought some paint at Lowes today and got this with it
BEETROOT is offline
post #478 of 521 Old 02-11-2012, 06:19 PM
JacKedUP4x4
Those ones snapped so I drilled all 4 out and in just gonna put bigger bolts back in. The one thats stuck is the one holding the seatbelt to the rollbar i just got a blade and plan on cuting it in half then using vice grips to pull the rest out
post #479 of 521 Old 02-11-2012, 06:22 PM Thread Starter
LuckRider
LuckRider's Avatar
Wow... I wonder where that came from As far as I know, Lowes doesn't carry any Magnet products.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #480 of 521 Old 02-11-2012, 06:37 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You joking? We don't sell to them
Where was the paint stick that you got it from Lowes??
Connect with us on:
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 01:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 12:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
