Monstaliner: A Full Install Write-Up - Page 27 - JeepForum.com
post #391 of 521 Old 06-14-2011, 03:08 AM
Boundless
Originally Posted by LuckRider View Post
I highly doubt there will be any better deals than the current one which ends when July comes IIRC. They are dropping the free shipping and charging a small flat rate for shipping. They will still include the free CS though... this is all IIRC.
As for the rolling, both works well. Honestly, I would suggest loading the roller rather than pouring. I found that it gave better results in terms of consistency of thickness and texture.
Thanks
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #392 of 521 Old 06-14-2011, 06:11 AM Thread Starter
LuckRider
LuckRider's Avatar
No problem, always happy to help.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #393 of 521 Old 06-14-2011, 06:52 AM
erickpl
erickpl's Avatar
Well, after a year of sun, snow, ice, heat, and daily use, I can say my Monstaliner is holding up VERY well. With the heat and humidity here in Alabama, the Monstaliner has been rock solid. My TJ is a bit warmer on the floorboards and I have no clue if it is any noisier or quieter, but I didn't line my tub for better sound or thermal insulation.
It works as advertised. It is VERY easy to keep clean when I take the time to clean the Jeep, and it provides sufficient grip unless my boots are covered in Alabama mud.
When I considered lining my tub, I was terrified at the prospect of ripping out the interior, spending the time to sand it down, clean it and then pray I don't screw up. But when it came down to it, Magnet's support, input from LuckRider/others, and family help all made this a ridiculously easy project as long as you took your time to do it right.
I even managed to make it look BETTER than it did before the liner. Whodathunkit?
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #394 of 521 Old 06-14-2011, 07:05 AM
mike_breaker_5
monstaliner + chassis saver = WINNING!
lol
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #395 of 521 Old 06-14-2011, 07:37 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The pouring seen in the videos was just a way to avoid mixing more coating needed to work from a roller pan. When working over large areas it's always easier to load the roller from a tray than to pour and spread
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #396 of 521 Old 06-14-2011, 09:19 AM
clg82
I just read thru 27 pages of pure Monstaliner Bliss! And I am fully convinced that I will probably be doing this fourth of july weekend.....Magnet, how long does it usually take to deliver from where you are to California? And also how is it shipped USPS? UPS? FEDEX? thanks again everyone for truly a great forum and thread!
clg82 is offline
post #397 of 521 Old 06-14-2011, 09:31 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
UPS ground. Allow 6 working days to west coast. I would order before next Wednesday
Connect with us on:
post #398 of 521 Old 06-17-2011, 11:18 PM
BEETROOT
Did mine today with Olive Drab Monstaliner. I have a few spots to touch up, but very happy with how everything turned out. The only issue I ran into was the stuff drying out on me in the roller pan, and then I kept getting clumps in the roller. I had to keep splashing MEK into the roller and into the gallon to be able to work with it.
It's still wet in these pics.
BEETROOT is offline
post #399 of 521 Old 06-18-2011, 01:48 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
At any time while working did you have the gallon can sitting open for more time than it takes to add more liquid to the roller pan?
Connect with us on:
post #400 of 521 Old 06-18-2011, 10:54 AM
BEETROOT
Nope. I only opened it for a few seconds at a time to pour more into the pan. The instructions say not to dilute the stuff with thinner, but is (was) it OK to mix in a little MEK to loosen it up?
BEETROOT is offline
post #401 of 521 Old 06-18-2011, 11:42 AM Thread Starter
LuckRider
LuckRider's Avatar
That looks good
Support Our Troops!
JFI Member #7:
post #402 of 521 Old 06-20-2011, 04:16 PM
clg82
One quick question for the OP or whoever can answer, how long did you wait between coats....I know I read somewhere thru here that you applied the second coat right away but I thought I read somewhere that you needed to wait 3-5 hours between coats?
clg82 is offline
post #403 of 521 Old 06-20-2011, 05:46 PM Thread Starter
LuckRider
LuckRider's Avatar
You need to wait for the liner to no longer be tacky to the touch. Depending on humidity and temp, this can be just a couple of hours, or take 6 hours. I would suggest about 4 hours to wait, but no more than 16.
Support Our Troops!
JFI Member #7:
post #404 of 521 Old 08-12-2011, 02:04 PM
TheDirtyGeneral
How do I get the front seat belts off lol, the bottom part to be specific. I'm on the midst of striping
The last few pieces out
Chris. I miss driving my Jeep. Can't wait to get into another one.
TheDirtyGeneral is offline
post #405 of 521 Old 08-12-2011, 02:23 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You talking about the housing part the belt rolls into that's bolted to the bottom of the roll bar
Connect with us on:
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 01:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 12:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
