Monstaliner: A Full Install Write-Up - Page 17 - JeepForum.com
post #241 of 516 Old 08-22-2010, 05:02 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by skey View Post
Eric (i.e. Magnetman) (Luckrider too, since you are the man) I am doing install this week. I am going to use Chassis Saver on rust places in driver's floorpan. Do I scuff entire Jeep, MEK, and then apply Saver? Do I just wire brush floorpan, apply Saver, then scuff rest of Jeep, and them MEK? What is best order to go in? How long do I wit between Saver and Monsta? Thanks.
I will post pics before and after.
Clean dirt first from floor pan areas then scuff and MEK wipe then apply CS.
While you wait for it to dry, scuff the rest of tub and then MEK wipe.
Minimum of 4 or 6 hours before applying Monstaliner over CS.
As long as it's not very sticky you can coat over it.
Looking forward to your photos.
Where in Alabama are you?
Regards
MagnetMan
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #242 of 516 Old 08-22-2010, 05:07 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
The Promo
MONSTALINER PROMO EXTENDED THRU SEPT 26th
Connect with us on:
post #243 of 516 Old 08-22-2010, 05:16 PM
skey
Location
I am in Odenville, Alabama. It is about 30 minutes Northeast of Birmingham. Thanks for info. i got email a while back for input. I will send as soon as done.
skey is offline
post #244 of 516 Old 08-22-2010, 05:19 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
My wife is from Cullman.
Connect with us on:
post #245 of 516 Old 08-22-2010, 06:02 PM
skey
Small world. My Uncle lives in West Point. Good friends in Bremen & Hanceville.
skey is offline
post #246 of 516 Old 08-22-2010, 10:37 PM Thread Starter
LuckRider
LuckRider's Avatar
That is a good plan if you are only throwing chassis saver on a few rust spots. When I did the Rubi (so the Jeep not pictured in this thread), I had to wash out the whole tub because there was this nasty yellow smoker residue on it. A quick cleaning with some simple green should do you well.
If you are planning on doing the whole tub with chassis saver, clean scuff and MEK before the chassis saver. Then follow the recommended times for coats (I believe it is wait 3 hours and no more than 24 to avoid scuffing again) and lay down the liner.
West Point might be a little far from MagnetMan, but it is about a 40 minute ride for me. Small world it is.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #247 of 516 Old 08-22-2010, 11:12 PM
Renegade88
Plan on ordering early this week, sent a pm to magnet man. Does anyone know if this kit comes in grey?
2006 LJ
PanhandlePierFishing.com
Renegade88 is offline
post #248 of 516 Old 08-22-2010, 11:27 PM Thread Starter
LuckRider
LuckRider's Avatar
Sadly not yet. I have heard of the issues with the colors, and to be honest, it sounds like less of a pain than it must be. The promo has been extended into September though.
I must ask, what is the big hype with gray? I can understand colors in general, but why gray?
Support Our Troops!
JFI Member #7:
post #249 of 516 Old 08-22-2010, 11:31 PM
Renegade88
I have a white jeep with a grey interior not really looking to put black in not that it would look bad tho.
2006 LJ
post #250 of 516 Old 08-23-2010, 07:16 AM
erickpl
erickpl's Avatar
If you get up to Huntsville, I have the Monstaliner installed and you're welcome to look it over. It's holding up REALLY well! Sure is nice not worrying about mildewing carpet any more!
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #251 of 516 Old 08-23-2010, 07:18 AM
erickpl
erickpl's Avatar
You still need to get down here and wheel Stony Lonesome out there in Cullman. We have a group of people going there Labor Day weekend.
-Paul
erickpl is offline
post #252 of 516 Old 08-23-2010, 07:47 PM
jr03
How does spraying with undercoat gun compare to rolling, is texture about the same? I want to try Monstaliner but haven't decided if I should roll it or spray or a little of both
jr03 is offline
post #253 of 516 Old 08-23-2010, 10:52 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I won't get down there again until Christmas. I contact you before then and we can meet up for lunch. My father-inlaw works in Huntsville for Reed Contracting/Asphalt so I get over there as well.
Connect with us on:
post #254 of 516 Old 08-23-2010, 10:53 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I'll double post as well for those that may not be following the vendor thread:
Thickness is pretty similar and I only say that not from measuring thickness but from how much coverage I got when rolling a job vs spraying.
I'll tell you straight though, I have 2 large bed panels in my warehouse that I rolled and sprayed a few months ago on the same day. If it was not for the holes in the corners of the sprayed panels that I used to hang them, even I have a hard time telling them apart. The roller texture is really amazing if you take your time and make sure you look for any overlap marks before you walk away from it and say done.
Another thing if anyone is leaning towards spray vs rolling. Spraying is a real pain. I thought it would be better to spray as well just to see what it was like. Rolling, even though it takes a bit longer to do is actually faster considering all the masking and cover-up you need to do when spraying.
It's one thing if you have a regular shop and do this every day to spray but as a one time thing, rolling is really the way to go.
This is just my personal opinion but I have a lot of experience so take it just as advice from what I have seen and done.
Connect with us on:
post #255 of 516 Old 08-23-2010, 10:59 PM
WILLY348
I think you could be MagnetMan's wing man Like Mr.Blaine for Vanco
You know quite a bit about his product/the process to do it.. not saying its a bad thing.. its very informative
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 01:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 12:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
