Monstaliner: A Full Install Write-Up - Page 15 - JeepForum.com
post #211 of 516 Old 06-06-2010, 11:24 PM Thread Starter
LuckRider
LuckRider's Avatar
Looks good. Why didn't you take the console out fully though? You were most of the way there.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #212 of 516 Old 06-06-2010, 11:29 PM
UltimateCC
I installed mine today as well, I will load pictures when I am all done
UltimateCC is offline
post #213 of 516 Old 06-06-2010, 11:38 PM
D-BOI
that looks great, i will do my underbody before the winter hits again, it looks like way to much work to do the interior especially sincei want to keep the carpet in there
D-BOI is offline
post #214 of 516 Old 06-06-2010, 11:47 PM
jrwhite07
Luck rider and others what did you do with the 4 silver bolts that hold the transfer case linkage bracket? I'm rolling tomorrow and that's all I have left thanks.
jrwhite07 is offline
post #215 of 516 Old 06-06-2010, 11:49 PM Thread Starter
LuckRider
LuckRider's Avatar
I rolled right over it, but you could tape them off. If you have the gold bracket instead of the black one, you will notice it if you tape it off. You could also back the bolt out enough to tape under it and then bolt it back into place so you don't get the bolt itself.
Support Our Troops!
JFI Member #7:
post #216 of 516 Old 06-07-2010, 09:20 AM
cadeucsb
It was an awkward angle to unbolt the airbag control from the console and it gave more than enough clearance to coat that area by just tying it up.
cadeucsb is offline
post #217 of 516 Old 06-07-2010, 09:25 AM Thread Starter
LuckRider
LuckRider's Avatar
I didn't know the older consoles covered the airbag control module. That is interesting.
Noted for future reference to others doing this project
Support Our Troops!
JFI Member #7:
post #218 of 516 Old 06-07-2010, 09:44 AM
cadeucsb
Yea, the airbag control, rear seat removal/brackets, the rear gate latch cover, and the two plastic covers for the cable pack that runs to my hardtop were the only slight differences compared to your guide.
Your guide was priceless btw, printed and out in the garage with me for all the removal/prep work.
cadeucsb is offline
post #219 of 516 Old 06-07-2010, 09:48 AM Thread Starter
LuckRider
LuckRider's Avatar
No problem, glad it could help with the tear down. I knew there were differences with the tail gate cover and the rear seat.... If you want to take a couple pics of those with bolts sizes, I would be more than happy to edit the guide to include that stuff for those with older TJs.
Support Our Troops!
JFI Member #7:
post #220 of 516 Old 06-07-2010, 10:02 AM
cadeucsb
sure, you want me to email them to you?
cadeucsb is offline
post #221 of 516 Old 06-07-2010, 10:09 AM Thread Starter
LuckRider
LuckRider's Avatar
You could do that: Luckrider7 at gmail dot com (helps defeat spammers writing it that way).
Support Our Troops!
JFI Member #7:
post #222 of 516 Old 06-07-2010, 10:11 AM
cadeucsb
Ill try to snap a few more close up pics tonight, note the bolt sizes and shoot em over.
cadeucsb is offline
post #223 of 516 Old 06-09-2010, 12:40 AM
TheDragonfly
Scuffed, Taped and MEKed
First Coat on the tub still wet
First coat on the Door still wet
Dried clean lines at the doors
Dried clean lines at the tailgate
You might also add that I used double sided foam mounting tape to fill the holes. They work like the foam earplugs except you can adjust size to fit.
TheDragonfly is offline
post #224 of 516 Old 06-09-2010, 01:40 AM
mike_breaker_5
Originally Posted by magnetman View Post
Update will be on Monday. Very soon now, in final testing mode
eagerly waiting for the color update.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #225 of 516 Old 06-18-2010, 12:31 AM
mike_breaker_5
colors colors colors colors colors colors colors colors colors colors colors colors colors colors colors colors?
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 02:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 08:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 01:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 11:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 09:43 AM
