Monstaliner: A Full Install Write-Up - Page 13 - JeepForum.com
post #181 of 516 Old 05-02-2010, 10:16 PM
lumpster
lumpster's Avatar
when the color liner comes out will it be a dull finish like the black?
lumpster is offline
post #182 of 516 Old 05-02-2010, 10:27 PM Thread Starter
LuckRider
LuckRider's Avatar
From what MagnetMan said in the intro thread, it will have a little more shine to it than the black thanks to the base. I think he would be the best to give info though.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #183 of 516 Old 05-04-2010, 12:12 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Colors will have a higher sheen than black but will not be too glossy.
Luckrider has a good memory!
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #184 of 516 Old 05-04-2010, 08:44 AM
mike_breaker_5
im dying to get some olive drab. how long till the colors are up for sale?
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #185 of 516 Old 05-26-2010, 11:17 AM
j_niko
2009 JK Wrangler
Crap.....I was just thinking about doing this. :lol:
j_niko is offline
post #186 of 516 Old 05-27-2010, 10:25 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2 - 3 more weeks max
Connect with us on:
post #187 of 516 Old 05-27-2010, 10:26 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Promo still going through Monday!
Connect with us on:
post #188 of 516 Old 05-27-2010, 11:00 PM
mike_breaker_5
are you going to do a similar promo for the color kits as well? what is an approximate price offset from black to the colors?
post #189 of 516 Old 05-27-2010, 11:00 PM
cadeucsb
How much pressure should we apply to the scour pad when sanding? I have white paint interior and I am not sure how to gauge if I have scoured enough. How hard is it to over sand it?
cadeucsb is offline
post #190 of 516 Old 05-27-2010, 11:03 PM Thread Starter
LuckRider
LuckRider's Avatar
No, it is not hard to over sand it. If you are unsure, keep the M.E.K. handy and wipe regularly. Stop that area when you see the paper towel turn white (ok, it is white already, you know what I mean).
Edit: I am going to have the same issue when I do the Rubi.
Support Our Troops!
JFI Member #7:
post #191 of 516 Old 05-27-2010, 11:07 PM
cadeucsb
yea, that makes sense, Ill run a test area to gauge how hard to go.
Am I reading your first post correctly that you can use MEK to wipe away accidents?
cadeucsb is offline
post #192 of 516 Old 05-27-2010, 11:15 PM
UltimateCC
Finally ordered mine in black
UltimateCC is offline
post #193 of 516 Old 05-27-2010, 11:50 PM Thread Starter
LuckRider
LuckRider's Avatar
While it is wet, yes you can. I was actually just going over the FAQ in paper version, so that is fresh in my mind.
The Patriot Blue and black look so great together. While the liner in Patriot Blue would looks sweet, the black/blue combo works well.
Support Our Troops!
JFI Member #7:
post #194 of 516 Old 05-28-2010, 12:09 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Using the scuff pad in the kit it's really impossible to over scuff.
You want to remove the gloss of the clear coat. You can even use 100 grit sandpaper if the scuff pad feels like it is wearing out and not scratching the surface anymore.
Connect with us on:
post #195 of 516 Old 05-28-2010, 12:15 AM Thread Starter
LuckRider
LuckRider's Avatar
You haven't sanded Jeep OEM paint then have you It is pretty thin. Ok, it is easy to sand through the clear, but the paint is a bit harder. I guess you would have to be trying to sand through the paint to actually do it.
Support Our Troops!
JFI Member #7:
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 02:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 08:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 01:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 11:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 09:43 AM
