Monstaliner: A Full Install Write-Up - Page 11 - JeepForum.com
post #151 of 521 Old 03-26-2010, 11:33 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Originally Posted by LuckRider View Post
I agree 100%. You will almost never sell. There is this one little parts store in town that mixes PPG paints, and they have cans everywhere of mixed paint. It is a mess because once they mix it, it usually sits with most of it still in there.
We have a few thousand gallons like that
Manufacturers of CHASSIS SAVER™ Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #152 of 521 Old 03-28-2010, 02:26 PM
BenchTT
Order placed. Where is everyone getting the MEK? Local paint store? Can I just use acetone?
BenchTT is offline
post #153 of 521 Old 03-28-2010, 02:43 PM
apexjeepinjoe
Ace Hardware.
~Joe~
2012 Wrangler Rubicon(my woman's ride)
2002 Wrangler Apex Edition(with lots of goodies)
1988 Comanche(stock for now)
1970 Jeepster Commando(a work In progress)
apexjeepinjoe is offline
post #154 of 521 Old 03-28-2010, 02:49 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Avoid acetone. Too flammable and it evaporates way too fast. MEK is best.
Also no lacquer thinner or alcohol.
Also get MEK at Home Depot or Lowes paint dept
Remember you are wiping surfaces to remove any waxes or tar and also the dust created by scuffing.
Wiping before and after scuff sanding is not a bad thing.
Connect with us on:
post #155 of 521 Old 04-04-2010, 01:20 AM
D-BOI
ok so im looking to purchase a bedliner for the underside of my xj and the underside of my doors, the thing is why would one pay 135 for this kit when u pol is only 99 bucks shipped on ebay. dont mean to be an arse just trying to learn more
D-BOI is offline
post #156 of 521 Old 04-04-2010, 01:27 AM Thread Starter
LuckRider
LuckRider's Avatar
This stuff is thicker and easier to clean. It can be sprayed with a shutz gun or rolled with the supplied roller. It supports our JF vendor. Made in America from a company in the coating and application business since 1915. Great customer service.
The biggest thing in my mind is the quality of the product. If you check out the Monstaliner Vendor Display, there is a lot of information. It is hard to describe the difference with Monsta because of how different it was designed.
Here is the Intro Thread: http://www.jeepforum.com/forum/f43/i...-liner-875162/
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #157 of 521 Old 04-18-2010, 05:40 PM
greensaharatj
First off, I love the write up LuckRider. Now for my question, I'm probably going to order this kit because of the free shipping and free chassis saver promotion, but I am wanting to go ahead and do my fender flares at the same time. Will the 1gal kit be enough to do the whole tub with two coats plus all four flares?
2003 Jeep TJ w/RC 3.25 lift rockin 35x12.50r15 Dunlop Mud Rovers on Crager Soft 8's, Currie HD Steering system, Delta Quad-Bar headlights, KC 55watt fogs, 130watt long range KC daylighters on the windshield, Smittybilt Tube Fenders, Smittybilt X20 10k Winch, Poison Spyder front Stinger--future stuff, SYE/CV Driveshaft, Rear corner armor, Engine/Oil skid, Tummy Tuck
Don't forget to wave :wave:
greensaharatj is offline
post #158 of 521 Old 04-18-2010, 06:14 PM Thread Starter
LuckRider
LuckRider's Avatar
If you look at my can, I had plenty left over for some extra stuff. Just don't forget to follow the guidelines for coating plastic. If you have questions, ask MagnetMan. I do know that you will need bulldog adhesion promoter.
Support Our Troops!
JFI Member #7:
post #159 of 521 Old 04-18-2010, 07:25 PM
irocz3489
Yes if you look at my post (#134 on page 9) i did all of flares and the 2 coats. There's a pic of how they came out too. I still had some left over after all that as well
irocz3489 is offline
post #160 of 521 Old 04-18-2010, 09:03 PM
greensaharatj
Awesome, thanks for the responses. Hopefully I'll get to do this in the next week or two, may have to wait till a three day weekend from school though
post #161 of 521 Old 04-20-2010, 06:12 PM
baron
Has anyone used it for a bed liner? Also, does it harden or stay rubber-like (sp?)
2007JK2DR
99TJ4.0L
baron is offline
post #162 of 521 Old 04-20-2010, 07:05 PM Thread Starter
LuckRider
LuckRider's Avatar
Hard like a plastic It was originally designed as a bed liner, and I believe FireKite is going to be using it in his Ford.
It has a great feel that isn't quite as plastic like as a plastic, but it definitely isn't rubbery. If I have to equate it to something familiar, look at the soft top of a Jeep and you should find those rubber foam things on the bows. The outer part of those foam pieces are very smooth. Monstaliner is kind of like that if that were hard.
Support Our Troops!
JFI Member #7:
post #163 of 521 Old 04-20-2010, 08:40 PM
baron
thanks... I just sent a PM to magnetman and this looks to be my next TJ and Dodge Ram projects...
2007JK2DR
99TJ4.0L
baron is offline
post #164 of 521 Old 04-21-2010, 01:18 AM
Azar
1997 XJ Cherokee
Would 1 gallon be enough for an interior of an XJ? Guessing probably not?
Azar is offline
post #165 of 521 Old 04-21-2010, 05:22 AM Thread Starter
LuckRider
LuckRider's Avatar
It is hard to say. I think you would get a better answer in the Vendor Display because I believe there have been a XJs that have done it.
Support Our Troops!
JFI Member #7:
install , liner , monstaliner , write-up , writeup
MONSTALINER- bedliner UltimateCC TJ Wrangler Technical Forum 26 08-14-2011 01:05 PM
Is there a write up on how do install a TT? cb19950 TJ Wrangler Technical Forum 23 08-04-2007 07:59 PM
Full Traction 6" Long Arm Kit Write-Up wayoflife TJ Wrangler Technical Forum 16 05-19-2006 12:46 AM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 10:10 PM
Brake install How-To Write up?? bam9382 TJ Wrangler Technical Forum 8 05-13-2005 08:43 AM
