Momentary horn switch help - JeepForum.com
post #1 of 7 Old 08-30-2013, 12:12 AM Thread Starter
thedaringmove
I have a momentary switch mounted and the ground. I can't find the 12V wire that goes to the horn. It's a 99... Anyone know the color or location or anything? Pictures would be heavenly
thedaringmove is offline
post #2 of 7 Old 08-30-2013, 07:41 AM
festerw
festerw's Avatar
Red/yellow wire in the left side kick panel should be the correct one.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 7 Old 08-30-2013, 09:01 AM Thread Starter
thedaringmove
So behind the steering column panel on the left side of the wheel?
post #4 of 7 Old 08-30-2013, 11:12 AM
festerw
festerw's Avatar
Shouldn't have to pull that panel it'll be on the left side of the footwell, on my 03 you can see if pretty well. Here's the 99 FSM page showing the location C107 is what you're looking for.
post #5 of 7 Old 08-30-2013, 01:39 PM Thread Starter
thedaringmove
Thanks again. So I found a yellow and red but I als found a yellow. It's the solid yellow?
post #6 of 7 Old 08-30-2013, 02:16 PM
festerw
festerw's Avatar
Should be a red wire with a yellow line.
post #7 of 7 Old 08-31-2013, 01:04 AM Thread Starter
thedaringmove
I see it. Lifting the jeep tomorrow. Once I get everything done ill go ahead and snip the wire. Thanks
