-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Momentary horn switch help (http://www.jeepforum.com/forum/f9/momentary-horn-switch-help-1568983/)
thedaringmove 08-30-2013 12:12 AM
I have a momentary switch mounted and the ground. I can't find the 12V wire that goes to the horn. It's a 99... Anyone know the color or location or anything? Pictures would be heavenly
festerw 08-30-2013 07:41 AM
Red/yellow wire in the left side kick panel should be the correct one.
thedaringmove 08-30-2013 09:01 AM
So behind the steering column panel on the left side of the wheel?
festerw 08-30-2013 11:12 AM
Shouldn't have to pull that panel it'll be on the left side of the footwell, on my 03 you can see if pretty well. Here's the 99 FSM page showing the location C107 is what you're looking for.
http://i46.photobucket.com/albums/f1...ps1d750e91.png
thedaringmove 08-30-2013 01:39 PM
Thanks again. So I found a yellow and red but I als found a yellow. It's the solid yellow?
festerw 08-30-2013 02:16 PM
Should be a red wire with a yellow line.
thedaringmove 08-31-2013 01:04 AM
I see it. Lifting the jeep tomorrow. Once I get everything done ill go ahead and snip the wire. Thanks
The time now is 04:49 AM.
