Quantcast Mods to make a tj more comfortable long distance? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mods to make a tj more comfortable long distance?
Old 10-10-2005, 02:10 PM   #1
loudog3114
Just wondering what people have done to their TJ to make em more comfortable. Mine is my DD, which never bothered me until now that I am doing IT consulting and constantly driving. I have even considered getting a ZJ, but I dont think its in the cards... so what can I do to make this thing a little more tollerable?
92 YJ, 35's, 6"
97 Honda CBR1100xx
loudog3114 is offline   Reply With Quote
Old 10-10-2005, 02:12 PM   #2
RCHavok797
If you want to make your TJ more comfortable drive a YJ for a week and then go back to your TJ.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote
Old 10-10-2005, 02:15 PM   #3
loudog3114
I have, heh.
92 YJ, 35's, 6"
97 Honda CBR1100xx
Old 10-10-2005, 02:15 PM   #4
Rocky529
Jeep
Rocky529's Avatar
Make sure you have a good quality shock for one thing. Another thing is making sure your tires are aired properly. When the tire shop mounted my 32s, they aired them to 50 psi. I got home and aired them to 30 psi and the ride is like night and day.
I can ride all day in my Jeep and not want to get out of it... maybe it has to be "for you" in order to really appreciate long rides.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 10-10-2005, 02:42 PM   #5
Wheelman
I have done a lot of long distance driving in my TJ and it seems like a bit more lumbar support would greatly increase the comfort level.
Wheelman is offline   Reply With Quote
Old 10-10-2005, 02:46 PM   #6
Rusty the Scoob
It would help for us to know what you find intolerable about it.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline   Reply With Quote
Old 10-10-2005, 02:50 PM   #7
DavidC
I had the same issue with 50lbs of air in my new MTR's after Goodyear did the install. Felt like I was driving on rocks. Got home from the dealer and checked, laughed a bit, then aired down to 30psi as well.
Major difference.
If soft top noise is problem, make sure to run the fan on your jeep.Keeps the top "inflated" and it will be less prone to make noise.
Good quality stereo and speakers help(Just saw that you have this!).Cell phone headset, so ya can shift and talk,GPS...beacuse they are cool.
Oh yeah, Hot Jeep Chick riding shotgun will make any trip more enjoyable.
2012 JKU Rubi,Auto, 4.10's, All black including hardtop and fenders. : P
99 Sahara D30/44 w ARB's and 4.10's, Warn 9.5TI,AA SYE & Wood's shaft,Raingler nets,Jeeperman trail skids,Warn gas tank and steering box skid's, BDS 2" springs, Currie control arms,32" MTR's,AEV Bridger wheels, custom made tire carrier bumper,Dynomax cat back JKS quicker disco's.PSC Trail Cage,Banks header,LiteDots.PSC Trail Corners.
92 CDN M101 trailer, 33" TSL Swampers,camo paint. Original camo tarp.
DavidC is offline   Reply With Quote
Old 10-10-2005, 02:50 PM   #8
In the open
Try mastercraft rubicon suspension seats. They are the type of seats that Baja racers use. Try quadratec.com
Also what about an armrest on the door. I have hard doors and that is the most uncomfortable thing about it.
[I]Jeep owners do it in the open[/I]
2004 Sahara, auto,D44, 3.73, tracloc,4wdiscs,31" MT/R
REBB,JKS Disc,Warn oil pan skid,Warn fuel tank skid
Mopar rock rails,15x8 eagle alloys
[URL=http://www.cardomain.com/ride/2149388]Our Jeep pics[/URL]
In the open is offline   Reply With Quote
Old 10-10-2005, 03:02 PM   #9
KaiserJeep
I made some seat spacers from 2"X2"X3/16ths steel tubing, spacing the seat up 2" and to the rear by 2" to better fit my size. I also added a dummy pedal I fabbed from steel and put up against the left side of the footwell, to put the left foot at the same distance as the right foot when cruising.
I added additional soundproofing - just look at an Unlimited on a dealer lot, and then screw the same size and thickness fiberboard panels to the floor sheetmetal from underneath, after painting with exterior paint. Still to do: a layer of insulation between the transmission tunnel and carpet. I discovered this Summer that in 100+ degrees a lot of heat leaks through and it's uncomfortable when cruising.
Speaking of cruising, if you do not have the Mopar cruise control, buy the parts and add it yourself, it's worth it.
When you lift your Jeep, don't use anything except OME, which can be had in 2.5" and 4" lift springs for shortarms. The combo of OME springs and shocks is more comfortable than a stock suspension, and real flexy.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline   Reply With Quote
Old 10-10-2005, 03:03 PM   #10
CoriolisSTORM
I'll unpimp your auto...
CoriolisSTORM's Avatar
2010 JK Wrangler
Only thing about the Rubicon Mastercraft seats is that they are to quote Quadratec's catalog "Not intended for street use." As much as I would like a pair in my TJ, I'll wait on that. Believe that's the ones you're talking about anyway...
Oy! kaiserjeep, what all exactly have you soundproofed in it? I'm thinking about the same thing for my TJ. Do you have any pics or ideas? What material(s) did you use?
Its like a (silly censor)roach, the Wrangler - you can't kill it And now there's a four door. Joy.
CoriolisSTORM is offline   Reply With Quote
Old 10-10-2005, 03:06 PM   #11
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Foam ear plugs. I have a whole sack of 'em for when I drive long distances. The first time I used them for a long trip, I was amazed I could actually HEAR after arriving at my destination.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 10-10-2005, 03:06 PM   #12
Wheelman
I second this.....Another great mod thats simple but useful on long trips This is the only option my TJ didn't have that I would've liked.
Old 10-10-2005, 03:07 PM   #13
kcphilaflyer
If you only have a soft top and are on the highway alot, go buy a pair of these and an mp3 player
http://www.bestbuy.com/site/olspage.jsp?skuId=6825297&type=product&productCate goryId=cat08352&id=1091101528169
cuts out 90% of the outside noise even with the top off.
something for the lower back always helps, but I usually only break that out for the long road trips.
2005 Red TJ
6 Cyl 4.0L Manual Transmission, D44 Rear, 3.73 Gearing
32x11.5x15 BFG MTs on 15x8 Ravines w/ Spidertrax 1.25" Wheel Spacers
2" RE BB, 1" PA BL, 1" MORE MML
AtoZ Rockers, Uniden/2ft Firestick(stolen), Nth Degree Oil Skid, JKS Discos
1986 Red CJ-7 Spring '89 - Spring '96, R.I.P.
Red Jeep Club Member #289
Pix
kcphilaflyer is offline   Reply With Quote
Old 10-10-2005, 03:14 PM   #14
loudog3114
Well the stereo was the first thing I upgraded, and I went all out, so im pretty much all set on the music front.
92 YJ, 35's, 6"
97 Honda CBR1100xx
Old 10-10-2005, 03:14 PM   #15
Rocky529
Jeep
Rocky529's Avatar
If his Jeep isn't prewired then he may not want to go this route. Wiring it into the computer and under the dash can be tedious... took me 4 hours taking my time.
Glock Forum
