modification process????? - JeepForum.com
post #1 of 5 Old 06-15-2004, 02:16 PM Thread Starter
Jeepin_Al
Just taking it easy!
ok, here is the problem, I have the dana 35 with 3.07's and drum brakes, I want 4.10's or 4.56's and disk brakes and a stronger axle to handle some 33's. I am going to get a ford 8.8 out of an explorer and swap it out rather then regear and reinforce the d35. I don't have the money to do everything at once, but I am going to be getting a set of RE adjustable control arms pretty quick and want to put an SYE/cv in and am wondering about the length of the CV. Can I get the SYE/CV now and install them and then do the 8.8 swap or is the length that much different? I am just floating an idea so any suggestions would be appreciated, thanks alot, AL
"rejected by the signature police"
Jeepin_Al is offline
post #2 of 5 Old 06-15-2004, 09:33 PM
pnshr99
pnshr99's Avatar
sye / cv length
I don't know for sure on length but I have a 6" fabtech longarm and my cv measures out at 17" center to center after the sye was put in. Itshould be the same if you have a smaller lift and should not matter if you do it before or after the lift is on.
pnshr99 is offline
post #3 of 5 Old 06-15-2004, 10:01 PM
igofshn
Locked @ both ends
igofshn's Avatar
When you do the 8.8 your driveshaft will have to be modified.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #4 of 5 Old 06-15-2004, 11:28 PM
EDM0656
All the reading I've done contradicts this. Going from a Dana 44 to a Ford 8.8 requires a longer driveshaft, but going from a Dana 35 to a Ford 8.8 should not. Keep reading or wait until someone replies that has done the swap.
99 Sport 4.0 5 speed
2" RE BB 1" Daystar body
32" BFG AT's
Crager Black Steel Wheels 3.75" backspace
Bestop Bikini
Mirror Movers and some lights
Cobra 29 CB
and a few more payments
EDM0656 is offline
post #5 of 5 Old 06-16-2004, 01:52 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I used my same driveshaft when I swapped my 35 for the 8.8 - I was fortunate. Worse case scenario is you may have to shorten your driveshaft which is pretty inexpensive.
Wheelin98TJ is online now
6:1 low range for a new process??? GodsRollerskate TJ Wrangler Technical Forum 22 01-22-2010 06:50 PM
D44 Swap Process missionAvs TJ Wrangler Technical Forum 14 09-16-2009 03:54 PM
New Process Gear cj847 Wrangler General Discussion 10 02-07-2009 09:11 AM
I don't know how many of you here would do this, but I am in the process and need som charlescho TJ Wrangler Technical Forum 28 05-30-2007 03:54 PM
In the process of doing a lift, need help! 89_Sahara YJ Wrangler Technical Forum 5 10-22-2005 12:32 PM
