Modification advice for light wheeling. - Page 3 - JeepForum.com
post #31 of 36 Old 07-15-2010, 11:56 PM
2006_Sport
Originally Posted by Boodyrider View Post
x2... x2... and Zack, I really want an invite to Flatlander's party/wheeling because I want to see your rig as well as Luckrider's up close... and I NEED to see Flatlander's build up close
Hah, mines nothing special, it'll have an aussie up front on 31s and a 2 inch lift. LR has a stock rubi. But I'll see what's up.
2006_Sport is offline
post #32 of 36 Old 07-16-2010, 05:54 PM Thread Starter
cam36
Hey guys antoher question...if I disconnect the sway bars it'll give the wheels better flex right...and is there anything more too it other than taking out the bolt?
cam36 is offline
post #33 of 36 Old 07-16-2010, 05:58 PM
biffgnar
biffgnar's Avatar
Correct. You will need zipties or bungies or something to tie up the links while they are disconnected.
And as to Rausch Creek, it is definitely worth a trip. Greens (and maybe easy blues) can be run stock.
Romney in 2020!
biffgnar is offline
post #34 of 36 Old 07-16-2010, 06:08 PM Thread Starter
cam36
Okay cool thanks man, and are they a ***** to re connect?....and me and my buddies are going the 27th and 28th if anyone wants to join
cam36 is offline
post #35 of 36 Old 07-16-2010, 06:10 PM
biffgnar
biffgnar's Avatar
Just make sure you are on flat terrain when you disconnect and then reconnect. Should be OK then.
Romney in 2020!
biffgnar is offline
post #36 of 36 Old 07-16-2010, 06:13 PM Thread Starter
cam36
Okay cool man sounds good thanks!
cam36 is offline
tj , wrangler , mod , modification , advice , help , suspension , lift , body lift , bl , tire
How does this modification sound? Advice? UAEjeep2009 JK Wrangler Technical Forum 7 01-25-2010 07:43 AM
Factory fog light modification question garybattles TJ Wrangler Technical Forum 13 01-07-2010 10:23 PM
rubi fog light override modification? steelefx4 TJ Wrangler Technical Forum 7 01-05-2008 09:29 PM
set up sound ok for light wheeling? jonsjeepthing TJ Wrangler Technical Forum 3 05-01-2006 06:08 AM
Light bar advice YJ? Why not? TJ Wrangler Technical Forum 11 06-09-2004 09:49 AM
