Modern classic flat fender alternatives - JeepForum.com
post #1 of 48 Old 02-24-2013, 03:52 PM Thread Starter
0IIIIIII0
I really like the look and idea of a plastic flat fender and really like the looks, but $300+ bucks for what it is seems awful high.
Does anyone else make something like that?
Sent from my TJ
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
- Samuel Adams
0IIIIIII0 is offline
post #2 of 48 Old 02-24-2013, 04:47 PM
stwilson74
stwilson74's Avatar
If you like them they are probably worth the money, I wheel with a guy that cracked his in a roll and they stood by their warranty, replaced his for some well earned damage. They hold up to normal wheeling stuff really well.
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat View Post
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
stwilson74 is offline
post #3 of 48 Old 02-24-2013, 05:11 PM
pmcjeep
Call them and see if they have any blems you may get a deal on a set of those.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #4 of 48 Old 02-24-2013, 09:44 PM
G Beasley
I bought blems and I cant find anything wrong with them . They are pretty unique in their looks and function and they arent cheap . You can get a similar look by cutting your fenders flat and that wont cost you much at all other than some turn signals . But when you brush up against a tree the MCE is going to spring back and the stock fender wont .
G Beasley is offline
post #5 of 48 Old 02-25-2013, 07:21 AM Thread Starter
0IIIIIII0
Already trimmed the flares, and have considered the hack job to the fenders, but don't think it will look "finished". If they're the only ones doing something like that, I uses they can charge whatever they want.
- Samuel Adams
post #6 of 48 Old 02-25-2013, 09:13 PM
G Beasley
With a little work you can get a finished look out of the stock fenders .
post #7 of 48 Old 02-25-2013, 09:19 PM
George Dickel
George Dickel's Avatar
Sent from my TJ
Almost 4 years after my restore/build, I finally ordered the Flat Flares this morning. I too had an aversion to dropping the big $$$ on plastic flares but found the Bushwackers that Q/T wants $490 for $379 on Amazon with free shipping. So I bit the bullet, saved the $120 and will sport the high dollar stuff but not without searching high and low for an alternative. Seems like a void in the marketplace for a more practical solution if you ask me...
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #8 of 48 Old 02-26-2013, 07:20 AM Thread Starter
0IIIIIII0
If only I knew anything about plastics... They canned that class at my high school before I was able to take it.
Sent from my TJ
- Samuel Adams
post #9 of 48 Old 02-26-2013, 07:25 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Now that looks good!
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #10 of 48 Old 02-26-2013, 07:50 AM
GMBNT42
Sent from my TJ
I agree the price is very high for a few strips of plastic and a ton of trimming of your old fender. But unless you fab/DIY, then thats about as cheap as it gets for a hiline style alternative to fit larger tires. Most of the aftermarket hiline fenders run double that price and up.......
GMBNT42 is offline
post #11 of 48 Old 02-26-2013, 07:53 AM
biffgnar
biffgnar's Avatar
MCEs are flat but they are not hilines
biffgnar is online now
post #12 of 48 Old 02-26-2013, 08:18 AM
GMBNT42
They way they are setup and "gutted" and clear much larger tires I would consider them a hiline style fender, even though they use the original hood. Same with the bolt on MC's........you know how many times Ive been approached asking where I got my hilines? It is what it is. They look the part, and technically have basically the same functionality as well too. But I know they technically aren't.
GMBNT42 is offline
post #13 of 48 Old 02-26-2013, 08:20 AM
biffgnar
biffgnar's Avatar
Now you want to argue about what is a hiline? Not interested. I know what hiline means to me (and I'd suggest to 99% of the rest of the people on JF). If you want it to mean something different to you, knock yourself out.
post #14 of 48 Old 02-26-2013, 08:37 AM
GMBNT42
You don't read well do you? I stated Hiline STYLE fender. Thats what they are. I said that twice now, did I ever state they ARE hiline fenders? NO. Thats what MCE deems them as well. Are you really just trying to start a silly argument over nothing........again?
GMBNT42 is offline
post #15 of 48 Old 02-26-2013, 08:53 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
WTF, hiline style?
MCE calls them a FLATTY fender.
Wheelin98TJ is offline
