Mode (vacuum) switch plug NEED HELP -
Go Back > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mode (vacuum) switch plug NEED HELP
6th annual beat your wife to the credit cards sale!!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRugged Ridge Products Promo Calendar - Promo Code 2016CAL
Unread 10-30-2015, 05:50 PM   #1
Does anybody know what the plug that connects into the mode switch is/where to get it. Mine is FRIED. I believe that is the reason my fan wont work. Everything else has been replaced, the blower motor, blower switch, resistor and nothing works and everything has power until I ripped the stupid mode switch apart and saw it melted the plastic and the plug that goes into the mode switch. One more thing, does anyone know where I can buy that panel ( i do not know what it is called) the panel that the knobs are on. I guess its called the HVAC panel
Ewolf is offline   Reply With Quote Quick reply to this message
Unread 10-31-2015, 01:08 AM   #2
AFSOC Retired
Knuckelhead's Avatar
Its called the A/C-Heater control panel and the switch is called the mode select switch, IIRC. The panel and separate switches should be available from the dealership...
Knuckelhead is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
