Mobil 1 Filter? - JeepForum.com
post #1 of 30 Old 01-03-2006, 11:43 AM Thread Starter
Ivan
Mobil 1 Filter?
Having a hard time tracking down the part number (Mobil's part number) for Mobil 1's oil filter for a 2001 Jeep Wrangler (4.0 of course).
Any one know the number or where to get it?????
One of the 1,993 Golden Eagles produced in 2006.
Ivan is offline
post #2 of 30 Old 01-03-2006, 11:55 AM
Difranco
Difranco's Avatar
Current Vehicle:
Year: 2001
Make: Jeep
Model: Wrangler
Engine Type: 6cyl. 4.0Liter Power-Tech
Filter matches for the vehicle you selected:
Mobil 1 Model M1-204
Other options
Fram Model PH16 <------ BAD CHOICE
Purolator Model L14670
Purolator Model PL14670
source: http://www.mobiloil.com/USA-English/...Care_Home.aspx
Orange Jeep Club Member #13--Metalhead Jeep Club Member #13--Poseur Jeep Club Member #13
Gun Control: Means never having to say "I missed you!"
FOR SALE: OE Rubicon Shocks / OE Rear Bumper / OE 3rd Brake light / OE Front Trackbar / OE Rear Trackbar -- PM for details and make your best offer.
Difranco is offline
post #3 of 30 Old 01-03-2006, 12:03 PM
Rusty the Scoob
Rusty the Scoob's Avatar
A filter for a Ford 5.0 (Fram PH8A or equivalent) is larger but bolts right up... extra filtration surface for free!
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline
post #4 of 30 Old 01-03-2006, 12:06 PM
Andy1100
Andy1100's Avatar
Ok, you got me......... reeled me in.
Why is the FRAM PH-16 a bad choice????
I've been using it on mine since day 1, now with 77,000 miles on it, it runs great and uses absolutely ZERO oil.
98 Sahara, Quick Discos, 33X10.5 BFG's, 3" Black Diamond Suspension Lift
Andy1100 is offline
post #5 of 30 Old 01-03-2006, 12:12 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Fram was bought out by Allied Signal years ago and since then, their quality has taken a big nose dive. The couple oil filter tests I've seen have all pretty much said the same thing, that Fram's filters had the worst quality and the most problems with leaky anti-drainback valves.
Jerry Bransford is offline
post #6 of 30 Old 01-03-2006, 12:12 PM
Rocky529
Rocky529's Avatar
Fram is no good since they were bought out.
I use the M1-204
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #7 of 30 Old 01-03-2006, 12:14 PM Thread Starter
Ivan
Other options
Thanks Difranco!
I looked all over the Mobil 1 site (I thought) and could not find any info on filters for specific autos.
Ivan is offline
post #8 of 30 Old 01-03-2006, 12:14 PM
Andy1100
Andy1100's Avatar
Hmmm thanks for the info. Guess I'll switch up filters!
Andy1100 is offline
post #9 of 30 Old 01-03-2006, 12:41 PM
Difranco
Difranco's Avatar
The best filters are the Pureolator filters especially their premium filter the "PureOne" (about $5.50 here) which is half the cost of the K&N ($12 to $15) or the Mobile 1 ($8 - 11).
When I first bought my TJ in August of '05, I spent the first 3,000 miles researching and reading about oil, filters and greases. I spent more time reading about that then about Jeeps and mods.
So the PureOne and Mobile 1 are what I use at every 6,000. I will be dropping the $40 dollars next month to have my used oil tested by a lab to see if I need to decrease/increase my Oil Change Interval or not.
Sidenote: I did have good results with Castrol Syntec in my old Nissan Frontier Crew Cab, after 90,000 miles it didn't burn any oil at all and I was doing oil changes about every 10,000 miles.
Difranco is offline
post #10 of 30 Old 01-03-2006, 12:55 PM
Difranco
Difranco's Avatar
Thanks Difranco!
No problem. Their access to that info is not easily found as you have to go thru their oil selection wizard.
Difranco is offline
post #11 of 30 Old 01-03-2006, 01:19 PM
alexb
2017 JK Wrangler
you can also use a bigger filter M-206
I'm using an oversized filter Mobil M-206 or Purolator PL-30001
alexb is offline
post #12 of 30 Old 01-03-2006, 01:32 PM
numnuts
Jerry Is wright on the fact Fram like to to cater to the wall mart... k mart croud. the filters are natoriuosly getting failures on there anti drainback system, and sence the TJ,S are horizontal to your block, you need a product that has super good antidrainback capabilities. Purolator wether it be PURE ONE, or reg purolator are good so is ac delco, I use the ford filter made by Bosch my self, in my TJ In my opnion Mobil 1, amsoil are hyped up in there marketing, Change your oil on a common bases and use a good rated filter. Hastings. lee maxi, PURE ONE, acdelco. Ford motercraft use to make excellent filters, purolator, wix, BOSCH, These all in my opioion, are good named filters that you dont have to pay 10.00 a pop for.
numnuts is offline
post #13 of 30 Old 01-03-2006, 02:01 PM
Polaris
Polaris's Avatar
crap, I've been using Fram for the past few years. What retailers carry the Pureolator, and is the PL-30001 the same size as the PH8A?
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
Polaris is offline
post #14 of 30 Old 01-03-2006, 02:03 PM
Jeepin' Rock Cl
I like the Pure One filter for the 5.0L Mustang, fits nicely and extra large filter.
Jeepin' Rock Cl is offline
post #15 of 30 Old 01-03-2006, 02:10 PM
MotownTom
Has anyone actually seen, first hand, an engine getting destroyed because it used a Fram filter? To be honest, I think it's an old wives tale.
I've used Fram filters (Tough Guard) for many, many years and never had any problems.
My '93 Cherokee had 84,000 miles on it when I sold it last March and she ran like a top. I'm using the same Fram filter on the new (in March) Rubi.
I've also used K & N drop in air filters for years with NO problems, although they get a bad rap too.
'05 Black Rubi 6-spd
MotownTom is offline
wix or mobil 1- oil filter? paroxysym TJ Wrangler Technical Forum 20 11-06-2011 05:29 PM
Mobil 1 Filter # nepatsfn JK Wrangler Technical Forum 4 06-18-2007 07:20 AM
Mobil 1? dieselcrackel TJ Wrangler Technical Forum 11 02-22-2006 12:17 PM
Mobil 1 filter source Headspace TJ Wrangler Technical Forum 20 07-20-2005 11:06 AM
Mobil 1 oil in the TJ Matt Graham TJ Wrangler Technical Forum 3 09-30-2002 08:26 AM
