MML raise shifter? - JeepForum.com
post #1 of 4 Old 01-12-2005, 03:32 PM Thread Starter
wakeboarder 21
MML raise shifter?
i have a Tcase drop with my RE lift and 1" BL so my sifter is pretty low... im adding a MML soon and was wondering if that would bring my shifter up any?
thanks in advance
98 TJ
5spd,4banger
RE 3.5 __ 1" BL__RE front adj. trac bar__Currie Anti Rock sway bar__33 BFG M/T with some black steelies__K&N Filter__CB___ Durango 4x4 Front Bumper
building for 37s
wakeboarder 21 is offline
post #2 of 4 Old 01-12-2005, 03:54 PM
hardwarp
bump...because I as well want to know the answer to this.
hardwarp is offline
post #3 of 4 Old 01-12-2005, 04:00 PM
Humberto Benavides
Humberto Benavides's Avatar
I got exact same set up on my rig, RE 3.5" 1"BL and 1"MML and still needed the tc lever drop bracket ! All jeeps are different but I bet you'll need it !
'03 Jeep Wrangler X Auto I6 4.0L, 3.5" RE Super Flex, 1" PA BL, M.O.R.E. 1" MML, 33x12.5x15 MT/R's, JKS Quick Discos, RE Front Adjustable Trackbar, Skyjacker Hydro7000 Shocks, OEM RUBICON Rocker Guards, WARN Steering Skidplate, Front Mopar Tow Hooks, Bushwacker 6" Extended Fender Flares, K&N drop-in air filter, Chicago Electric Winch, SS light bar with 4 Hella 500 Driving Lights, and stock no more !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Humberto Benavides is offline
post #4 of 4 Old 01-12-2005, 04:08 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
it will bring the shifter up a bit. it may also eliminate the need for the transfer case drop kit
you can shim the 1" mml to 1.5" or whatever you can fit [depends on body lift] and this will help very much with your drive line angles.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
Need to raise my bumper merril24 TJ Wrangler Technical Forum 16 02-22-2008 07:28 AM
Raise seats? TJamz TJ Wrangler Technical Forum 3 02-15-2008 03:04 PM
breathers????????? how to raise cb19950 TJ Wrangler Technical Forum 8 05-24-2006 10:18 AM
How to raise a soft top? JeepVroom TJ Wrangler Technical Forum 19 09-20-2005 05:24 PM
how much should i raise my yj ????? off-road arkie YJ Wrangler Technical Forum 8 03-11-2002 10:12 AM
