Missing Backfire at every startup - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Missing Backfire at every startup
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff XJ Unirail Channel Reinforcement....
Unread 11-28-2014, 06:54 PM   #1
ssgpate
Hello, I have a 1997 Jeep Wrangler recently purchased. Every time I start the vehicle about 15 seconds later it starts missing or backfiring and after about 4-6 seconds clears right up and doesn't do it again until the next startup. If you put it to the floor it will go right through themissing but I should not have to do that. It misses hot or cold it does not matter. I have replaced the following parts with no change to the situation.
The Jeep runs great other then that one issue at startup. at this point I need some interference to figure this out as I am running out of parts to replace. I didn't mind buying the parts anyhow just so I will have all new parts but at this point im tired of spending money. Any help is much appreciated.
Rear O2 sensor
New PCU
MAP sensor
IAC Motor
TPS
Plugs
Wires
Rotary button
Distributor cap
ssgpate is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 07:06 PM   #2
chevy2169
Wires plugged in incorrect firing order? Bad distributor timing?
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 07:24 PM   #3
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Mine has done that for years. Just let it warm up a minute.
"It always seems impossible until it is done." -Nelson Mandela
My Epic Five-Week Cross-Country Jeep Safari
SpaceWrangler is offline   Reply With Quote Quick reply to this message
Unread 11-28-2014, 07:43 PM   #4
ssgpate
Yes they are, other then the few seconds at startup it runs perfect
I know man but that is annoying and there has got to be a reason for this stumble.
Unread 11-28-2014, 08:33 PM   #5
SpaceWrangler
Gnarly Adventurer
The issue might be low fuel pressure at startup, resulting from [partial] fuel rail leakdown overnight, back into the tank.
Cycle the ignition switch a couple times to "prime" the fuel system and see how she likes it.
Unread 11-29-2014, 03:24 AM   #6
Jonny Jeep
Jonny Jeep's Avatar
It's happened to mine before. It's a failed heater in the upstream O2 sensor.
Unplug the sensor, the connector is clipped to the intake manifold near the firewall. If you find the problem doesn't occur with the sensor unplugged, replace the sensor. If it were to still happen with the sensor unplugged the sensor would not be the cause.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 11-29-2014, 06:47 AM   #7
ssgpate
Would that matter if the vehicle is warm? mine does it hot or cold. I think the front o2 is he only sensor I have not replaced.
Unread 11-29-2014, 04:55 PM   #8
Jonny Jeep
Jonny Jeep's Avatar
Depends how bad the heater element has gone and just how cold it gets between starts.
Disconnecting the sensor is a free and easy way of finding out if it's the cause of your problems.
Sent from my B15 using JeepForum
Unread 12-10-2014, 06:06 PM   #9
ssgpate
Johnny Jeep thanks you were right it was a failed upstream o2 sensor, the Jeep has not missed since I replaced it. Thanks
Unread 12-11-2014, 03:46 AM   #10
Jonny Jeep
Jonny Jeep's Avatar
Thanks for the update. It helps if threads come to a conclusion when they are found by a search.
Unread 12-12-2014, 12:28 AM   #11
oakmckinley
Huh? This mindset doesn't make any sense to me? Why would you instruct someone to just ignore a problem when they clearly asked for help with fixing it?
PO I'm glad you got it fixed!
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 10:59 AM   #12
ssgpate
I'm a tech Advisor on Modded Mustangs, and I would never give advice to a person and say deal with it I have been for years. There is always a solution to every problem you just have to be willing to dig in the weeds.
Although I was optimistic about the resolution I proceeded with the install anyhow. It doesn't make sense why it would buck like that because I thought the PCU was in open loop until it warmed up and bypassed the front o2 sensor.
Either way she is fixed and I appreciate the advice.
Spacewrangler my advice to you would be change your front o2 sensor and report back to this thread with the outcome.
Unread 12-13-2014, 11:42 AM   #13
Jonny Jeep
Jonny Jeep's Avatar
Originally Posted by ssgpate View Post
... It doesn't make sense why it would buck like that because I thought the PCU was in open loop until it warmed up and bypassed the front o2 sensor...
I didn't go into the detail of why these symptoms occur in this thread. Having a look at post #9 in the thread linked below should help it make more sense...
http://www.jeepforum.com/forum/f9/scan-tool-2855634/
