misfire when I hit a bump - JeepForum.com
post #1 of 7 Old 06-10-2008, 11:06 AM Thread Starter
zpedrick
Hey everyone, I have this problem that's really starting to piss me off... Every time I hit a bump in the road my engine sputters/miss fires. Sometimes the rpm gauge shows the rpm's going up really high or down and sometimes it doesn't change at all. I've gotten an error code before, 1391 (way to be descriptive Jeep). Also the up shift light would come on in 5th gear, but I think if you need one of those lights, you should drive an automatic, so I removed the bulb, don't know if it's still doing that. I've replaced the cam shaft position sensor, but it hasn't fixed the problem. So the only other things I can think of are, cam shaft position sensor, or the computer (ECU) or something else??? It's a 99 6-cyl 5-speed. So just a couple questions, hopefully someone knows...
1.) What controls the rpm gauge (i know it's not simple but is it the cam or crank position sensor (or both))?
2.) If I do a tune up on the ignition system http://www.quadratec.com/products/17610_60X_PG.htm will it also replace the crank position sensor? (My guess is yes since it requires an adapter plug, just want to make sure.)
3.) If I were to replace the computer, A.) Can I do it myself=(read B) B.) Do I have to also replace the gauge cluster (I remember reading something somewhere that the cluster and computer will no work if only one of them is replaced). Does it have to be programmed at a dealership?
4.) Could it be the knock sensor?
Sorry for the long post, but I've asked a lot of people and everyone shrugs, someone's got to have at least an idea. If I can't fix this thing I'm going to gut the entire Jeep and "upgrade" to an LS2. But I don't want to do that, I'm broke! THANKS
zpedrick is offline
post #2 of 7 Old 06-10-2008, 11:28 AM
mdm
Farm Wheeler
There's no knock sensor on your Jeep.
If you have a miss when you hit a bump it sounds like you have an electrical problem. A loose plug, a broken wire, ... Something is opening when you hit a bump. Simulate the bumps by shaking the wiring, moving plugs, move the coil rail, etc.
mdm is offline
post #3 of 7 Old 06-10-2008, 11:28 AM
klimb2xs
Here are a few things I would check.
Plug wires and rotor wire. One of these could be bad, shorting out or opening, causing a drop in RPM.
TPS - Could be dirty
Wiggle all of the electrical conectots while the engine is running. Inspect the wiring harnes for and bare wires that could be shorting to ground.
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline
post #4 of 7 Old 06-10-2008, 12:07 PM
Jerky bump
..engine ground.. battery clamps..corroded terminals
My jeep makes a ticking noise too
It has done it since it was new
I couldn't care less- I must confess
I use FRAM filters too!
Jerky bump is offline
post #5 of 7 Old 06-10-2008, 01:57 PM Thread Starter
zpedrick
PROOF that jeeps have a personality
I have living (dead) proof that jeeps have a personality... SHE JUST DIED hahaha. It wasn't 30 minutes after I posted this, pulled into the florist parking lot (a dozen roses for the lady). The lady in the store said don't leave these in your car in this heat (101.F) or they'll wilt, I said yeah, I know. Went out to start the Jeep, and she sputtered and then quit, it turns over but wont start. The Jeep must have gotten jealous, or mad that I was talking about it. Oh well, I'll let the mechanic figure it out, it's too hot to mess with it today. Thanks people, I'll post when I find out what it was.
zpedrick is offline
post #6 of 7 Old 06-10-2008, 09:50 PM
BigDaddyChoice
Is the backfire from the exhaust or the intake manifold?
If the backfire is from your tailpipe (imbalance in air to fuel ratio where fuel is too rich), then I had the exact same problem this past winter.
My mechanic and I spent weeks diagnosing and trying to recreate the problem, but when the Jeep was stationary, nothing ever happened. There was never a code recorded when hooked up for diagnostics.
There were times when the Jeep ran great for days and then other times, the RPM would shoot up and down and the engine threatened to stall.
I ended up replacing the throttle position sensor, and the idle air control sensor -- but to no avail.
Finally, my Jeep stalled on me in February and I could not restart it. I had it towed to my mechanic's shop where finally, he found the culprit...
It was a broken wire from the ignition coil that, from time to time whenever I hit a bump in the road, a bare wire would make contact with the engine block and short out. Keep in mind that this is the same cluster of wires that he considered as a possible cause previously.
He had to strip the protective plastic loom to uncover a single wire (from the dozens) that had a tiny tear in the plastic covering that would intermittently cause me grief.
Once properly spliced, soldered, heat shrinked and tied back in under the loom, the problem never came back.
FUGIT IRREPARABILE TEMPUS... CARPE DIEM!
"Drive it there, wheel it, drive it home"
JEEP OBSESSION: Testing the limits of financial stability.
Windtunnel failed since September, 2000
BigDaddyChoice is offline
post #7 of 7 Old 06-11-2008, 07:26 AM Thread Starter
zpedrick
Ok, sounds exactly like my problem, i'll look at it asap. THANKS!
zpedrick is offline
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 03:57 PM
are the bump stops suposed to hit when i go over a bump? MC_NickP TJ Wrangler Technical Forum 10 03-01-2009 06:40 PM
Misfire - Please help :) mylogylo YJ Wrangler Technical Forum 7 08-07-2007 06:28 PM
Misfire mibble98 TJ Wrangler Technical Forum 0 01-30-2007 06:53 AM
Misfire Flanker11 TJ Wrangler Technical Forum 1 12-10-2004 06:20 PM
