Misfire on cylinder 1 and 6 - JeepForum.com
post #1 of 4 Old 12-07-2010, 07:25 PM Thread Starter
ohwillyb
I just had a Jasper motor "4.0" installed in my jeep in march a few weeks ago I started having problems with my jeep running at low speeds it seems to loose power but if i get it on the freeway and get it up to the speed limit its fine. And when it does it I can turn off the jeep and turn it back on and its fine as long as I get it up to freeway speeds. The check Engine light is on an im getting misfire codes from 1 and 6.
My Mechanic has changed the coil packs, cam sensor, and checked the injectors and its still not right so he suggested I take it to the dealer to get the CPU checked and it has came up fine. I have seen this topic discussed here but no answers have yet been provided.
Thanks for the Help.
ohwillyb is offline
post #2 of 4 Old 12-07-2010, 07:30 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Welcome to the forum, and for that symptom I'd probably suspect the camshaft position sensor mounted where the distributor used to be may be out of time. It takes an experienced Jeep tech maybe 20 minutes to check and adjust the timing for that particular sensor.
Jerry Bransford is offline
post #3 of 4 Old 12-07-2010, 07:51 PM
jakemnm848
I had the same problem a few months ago, I replaced plugs, coil, cam sensor, and last not least the PCM. When I would tap on the PCM it would work fine then go to **** again so I figured it was the PCM. Installed a new one and same thing. So I started cuting the covers on all the wiring around the PCM and coil pack and found two wires near the PCM that were shorting out against each other and that was causing it to misfire.
Anyways make sure to check all your wiring before replacing everything. It might save you alot of money.
jakemnm848 is offline
post #4 of 4 Old 01-09-2011, 07:04 PM Thread Starter
ohwillyb
It turned out to be a bad motor from jasper, the valve in cylinder 1 wasn't closing all the the way a compression test of cylinder 1 confirmed this and the motor was replaced.
ohwillyb is offline
random cylinder misfire, misfire 1,2,4,5,6? f100ranger TJ Wrangler Technical Forum 11 07-23-2011 09:56 PM
Misfire Cylinder 3 SunNuclear TJ Wrangler Technical Forum 3 08-09-2010 05:25 PM
Cylinder 4,5, and 6 misfire? What does this mean chaznad TJ Wrangler Technical Forum 4 04-02-2009 08:36 AM
Cylinder 1 Misfire. Please Help erbizzle TJ Wrangler Technical Forum 5 03-11-2008 08:28 AM
Cylinder 2 misfire dead cylinder plenty of fuel Mel16m TJ Wrangler Technical Forum 10 11-27-2007 10:52 AM
