Mirror relocator with light and CB mount. - JeepForum.com
post #1 of 24 Old 05-16-2011, 09:33 PM Thread Starter
bgCJ7
Ok I know a few/many of you have built mirror relocators.
I like to build my own items for my jeep when i can.
So I decided to take a stab at it.
What I did was measure my A-Pillar and design on cad what
I wanted. Then me and a coworker made a prototype to see if
it would work. I was happy with the way it looked.
I contacted a local shop that had a water jet and had them
cut the parts out so they were all the same since all I had
at my disposal was a band saw.
Brought them back to my work shop and welded them up
drilled my holes, primed & painted, and finally mounted them.
You will notice in the pictures that there is a small hole in
between the mirror and light, that is for my cb antenna's
but I have not decided which ones I want yet so I have not
finished drilled them yet.
Thanks for looking and let me know what you think.
[IMG][/IMG]
bgCJ7 is offline
post #2 of 24 Old 05-16-2011, 09:36 PM
gixxerphil
Looks good, can you actually see out of the pass side mirror? I had a set and the pass side was useless if the doors were on
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline
post #3 of 24 Old 05-16-2011, 09:52 PM Thread Starter
bgCJ7
Thanks!!
Well I moved them outboard about 1" more than the ones you can buy from the stores. I can see enough to change lanes but not much else.
I am going to get the small stick on mirrors for that side and put int the bottom corner to help with actually being able to see out of it.
bgCJ7 is offline
post #4 of 24 Old 05-17-2011, 05:43 AM
crusher242
I really like that bracket. I always wanted to put my spots up high but my Kongo Cage took up that area. Nice
Hold onto something... Quick!!!
crusher242 is offline
post #5 of 24 Old 05-17-2011, 03:58 PM Thread Starter
bgCJ7
Thanks it's good to know others like my idea also.
bgCJ7 is offline
post #6 of 24 Old 05-17-2011, 04:04 PM Thread Starter
bgCJ7
This is the view I have out the passenger side mirror, without moving. It is usable.
bgCJ7 is offline
post #7 of 24 Old 05-17-2011, 06:43 PM
Getodd1
How much would you want to make me a set?
Getodd1 is offline
post #8 of 24 Old 05-17-2011, 07:03 PM Thread Starter
bgCJ7
Gosh hadn't really thought about that. I have $40 just in materials in mine.
bgCJ7 is offline
post #9 of 24 Old 05-17-2011, 07:06 PM
Deacon
Deacon's Avatar
I'm interested to see how the CB mount works out. Will that give you a good enough RF ground to get it working really well?
Deacon is offline
post #10 of 24 Old 05-17-2011, 07:06 PM
fang_x
is there enough room to allow the windshield to drop still? or would it make contact with the light?
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #11 of 24 Old 05-17-2011, 07:19 PM
kdb97tj
Thoughts are a great looking bracket I want a set lol
97 tj 4.0 5 sp
kdb97tj is offline
post #12 of 24 Old 05-17-2011, 07:32 PM Thread Starter
bgCJ7
Thanks all!!
I am interested in the ground also. As for the windshield I have never dropped mine but I am sure it would hit the lights, I believe I will have to check that out next time the top comes off.
bgCJ7 is offline
post #13 of 24 Old 05-18-2011, 07:13 AM
duanewhatley
Those are really cool looking, I wouldnt mind having a set of those myself!
duanewhatley is offline
post #14 of 24 Old 05-18-2011, 07:17 AM
pedal_damn_it
they look great!
pedal_damn_it is offline
post #15 of 24 Old 05-18-2011, 08:34 AM
Fropleyqk
Fropleyqk's Avatar
Good job dude. I like em.
Fropleyqk is offline
diy , fab , lights , mirror
Mirror relocator brackets... Foofighter23 TJ Wrangler Technical Forum 9 08-04-2010 06:38 PM
mirror relocator brackets mattman8706 JK Wrangler Technical Forum 7 09-11-2009 05:13 PM
Mirror Relocator removal SonofSam02 YJ Wrangler Technical Forum 3 12-18-2006 08:33 PM
Homemade Mirror Relocator Is this ugly? M1Shooter TJ Wrangler Technical Forum 21 05-01-2005 10:55 AM
Warrior Windshield light mount and mirror relocator Install...` Cidk TJ Wrangler Technical Forum 4 02-29-2004 11:57 AM
