Quantcast Mirror mounts, movers, and after markets- help!!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mirror mounts, movers, and after markets- help!!!
Old 06-19-2007, 07:12 PM   #16
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
$40 at Qtec
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Old 06-19-2007, 07:30 PM   #17
VICTIM_OF_PAIN
[QUOTE=Grewe02]$40 at Qtec[QUOTE]
I couldn't get my mirrors apart to even try to use that one.
[COLOR="Gray"]
[B]Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.[/B][/COLOR]
Current - 2008 Unlimited Wrangler Rubicon. Stock suspension and tires (for now), Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, and a Skid Row Evap Canister Skid plate.
[B]It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt[/B].
[URL="www.myspace.com/victimofpain"]www.myspace.com/victimofpain[/URL]
[URL="www.victimofpain.com"]www.victimofpain.com[/URL]
VICTIM_OF_PAIN is offline   Reply With Quote
Old 06-20-2007, 11:05 AM   #18
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
I didn't have a chance to pull the mirrors off as my father in law is at my house and we went out with him lastnight but here are some pictures I snapped this morning you can look at where they mount and see if you already have bolts there that wouldn't requite any drilling. I'm guessing you do.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off)
TrailWorthyFab is offline   Reply With Quote
Old 06-20-2007, 11:11 AM   #19
TrailWorthyFab
TrailWorthyFab.com
Originally Posted by cvaria
did you have to drill? i like the way they look but i'm trying to avoid the drill. i saw those on ebay.
If you look at the picture posted above my last posts you will see where a guy was showing you his hing mounted mirrors. On the windshied frame there are 2 bolts. Those are the same 2 bolts that hold the Mirrirs on my jeep. Good luck. Oh.........and by the way. Feel lucky. I don't take my digital camera home from work 50 miles run out to the garage at 6 am and snap pictures. Go to photobucket to upload them after taking the camera back another 50 miles to work. Good luck!
Todd
Old 06-20-2007, 11:12 AM   #20
tjwoo
x2 on the Jeepit brackets. I've had them for a bit and they take seconds to put on and take off. Here's the best pic I can find of it on my Jeep, I can take a closer shot if wanted.
tjwoo is offline   Reply With Quote
Old 06-20-2007, 11:12 AM   #21
bigV
Originally Posted by Grewe02
$40 at Qtec
I got the same brackets, but paid $27 from here: http://www.4x4rockshop.com/scripts/prodView.asp?idproduct=9871
bigV is offline   Reply With Quote
Old 06-20-2007, 11:15 AM   #22
tjwoo
Old 06-20-2007, 11:58 AM   #23
trail97
Got 2 8 dollar mirrors at pep boys. Took 2 old ski poles. Took baskets off poles. Mounted mirrors on poles. Stuck pointy ends of poles into hinge holes (fit good) and bent them, easy to do, so the top of poles lean against roll cage just behind wind shield. cut off poles and capped the ragged end and attached that to roll cage. Now have a 2 ft. long pole on which mirror can be raise and lowered to find best viewing.Total cost...cheap. Ease of use...simple with no threads to tighten. viewing?...can be adjusted ad nauseum. Mounting time?...seconds. My kind of thing...cheeres
You are a real Jeeper if....The weatherman says "Stay in, it's dangerous" and you think "Time to go wheeling":D
trail97 is offline   Reply With Quote
Glock Forum
