Mileage of early TJ's vs. latter - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mileage of early TJ's vs. latter
Jeep Wrangler Exhaust Manifold97-06 Jeep TJ 03-06 LJ 4" Rough Country Suspension liRancho Shocktober is here for fall 2015!!!!
Unread 11-10-2010, 05:04 PM   #16
Hella
04 Rubi with the 42RLE auto and I get 13 city and highway with 33's and stock gears..
04 TJ "Leyla" Rubi..
Hella is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 05:23 PM   #17
DezertTJ
Phrasing
DezertTJ's Avatar
my 03 rubi. auto, 4.10 gears, 35's gets 17-19 on the highway but thats a flat desert highway haha
thats with cooper stt's
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 06:08 PM   #18
Griff97
I know this is mainly about 4.0s but I check the mpg of my '97 2.5 recently. It was 15.5 with 4.10s ax5 and a 34 ltb. I'm about to swap to 4.88 so I hope that helps it. I was getting 14.0 before swapping a 4.0 throttle body onto it. Probably 85% city 15% hwy.
Griff97 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 07:38 PM   #19
viperbluelx
My 98 with 35's, 4.10's and 3-speed auto is averaging 10mpg. Speedo is calibrated and within 1mph of GPS.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 07:50 PM   #20
LJameson
My LJ gets anywhere between 14-16 while my 2000 TJ gets between 12-14. LJ has the 42RLE while the TJ has the 32RH.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 07:56 PM   #21
hustler905
Originally Posted by bottlerocket91 View Post
The 6 speed manual isnt much better than the 5 speed as far as the overdrive goes. Just has a taller first gear
You mean a shorter first gear.
Tall gears are high.
Short gears are low.
hustler905 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 08:37 PM   #22
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
2000 Sport with 35's and 456's (32RH), 17 mpg on the highway...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 08:43 PM   #23
flatlander757
On my 03 Sport I get 9.5mpg on 40s w/ 5.86s all city stop and go driving... I don't know what you guys are complaining about
Every Jeep is different... I think it's best to just leave it at that.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 08:52 PM   #24
DustinS
2011 JK Wrangler
My guess to answer your question is that later models got a number of upgraded parts and were often more option-laden then earlier models. Extra weight from options, especially ones that affect aerodynamics, could play a role.
2011 Wrangler Rubicon, Zone 3" lift, 3/4" spacers, SRC Front and Rear bumpers, Bushwacker flares.
DustinS is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 08:57 PM   #25
bottlerocket91
Yea I was actually re-thinking that post on the way home today and realized I messed it up lol. Shorter gears
bottlerocket91 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 09:13 PM   #26
CaptainSlow001
'98 Sport, 43k miles. I can get 18 around town if I try.... and 10 if I don't.
"Throw a pack of Skittles in the toilet and flush. There's your NASCAR race"
CaptainSlow001 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:05 PM   #27
buddastrat
Yeah I remember with my '97 TJ, on a full tank I'd get to 350 miles on the tripmeter before the low fuel warning. Then I'd fill 17 gallons almost every time. That was with those Grizzly wheels and stock tires, 3.07.
The '98 with 3.73 and 31's would get to 260 and I'd put in 17. That was so consistent for years.
With the '06...let's just say I'm just lucky I don't have to drive too much.
buddastrat is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:12 PM   #28
buddastrat
I just meant around town, it seems I can fine tune the driving a bit more with the six, for ex. I notice I can take a corner in 3rd gear very easily without lugging. In my 5 speed I was at higher RPMs because I'd be in 2nd. No way I could take a corner in 3rd, without lugging. Just thought keeping RPM's low would help with mileage.
I try to drive with egg between the foot and gas pedal philosophy, it doesn't seem to matter.
Unread 11-11-2010, 06:20 AM   #29
clockworkoranj
My 05 LJ auto w/stock tires/wheels, minimal mods and 24k miles gets 15 mpg +/-1 around town no matter how I change my driving habits (within reason). The only thing that has seemed to make a impact is that I am consistently closer to 16 since I found a local go juice station that is ethanol free. Seems to run smoother at idle as well, but I have a vivid imagination.
clockworkoranj is offline   Reply With Quote Quick reply to this message
emission , miles per gallon , mpg , tj
