Mileage of early TJ's vs. latter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mileage of early TJ's vs. latter
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-10-2010, 09:25 AM   #1
buddastrat
Why did the early ones get decent mileage? I was getting 20 mpg with city/HW driving in a '97. My '98 was real good too. About 17, but I put on 31's. Speedos was calibrated.
My 06 is miserable. Doesn't help that it's a rubi and I read it carries an extra 500 lbs. But still way low. Even with a six speed that lets me keep RPM's a bit lower with city driving.
On this site, it reports earlier TJ's did get better mileage. Are there more emission stuff on the later ones?
http://www.fueleconomy.gov/feg/bymake/Jeep1997.shtml
buddastrat is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:03 AM   #2
fang_x
the newer ones in theory should have better gas mileage because of the rounded mirrors, they are more aerodynamic then the square mirrors of prevouis years.
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:15 AM   #3
BYuen
The later model TJs do have more emission controls than earlier models, but I'm not sure how greatly it affects mpg.
BYuen is online now   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:20 AM   #4
TheBoogieman
Evil Inside.
TheBoogieman's Avatar
I got 18+ mpg highway with my 98' 5 speed with 35's and stock 3.73 gears.My brother's 05' 6 speed Willy's edition on 35's with stock gears gets the same.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 10:48 AM   #5
PDX_XJ
I think you're probably right.
The later models have a redesigned intake manifold to make up for power losses caused by the controls on the exhaust. The redesigned intake manifold lets more air into the engine (and consequently burns more fuel) raising power back up to where it should be.
I'm guessing since the engine is burning more fuel to produce the same power, that's why your mpg sucks so bad in later years. Sorry guys. But thanks for not killing the planet!
It's a popular swap for older style Jeeps (TJs, XJs, and Grands)... I've read gains of anywhere from 10 to 25 hp.
Old style left, new style right:
My '98 (3.07's on 31's, never use 5th gear) gets 15-16 mpg on a 50/50 mix of city/highway, though I have a depleted uranium right foot.
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 12:15 PM   #6
buddastrat
All highway I was able to get in the 20's, with 31's. Look at the link I posted. It shows the mileage dropping every few years.
Unread 11-10-2010, 12:22 PM   #7
buddastrat
Is that why the HP increased? I think around '01 it went up. The latter ones did seem a little more peppy to me. Back in '06 I read some report on 0-60 times where the 05-06's had the best times, due to the revised engine and six speed. But it's such a guzzler.
Unread 11-10-2010, 12:32 PM   #8
jeep308
it tells about the increases and what was changed to make the power increase in the TJ specs in the FAQ
jeep308 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 01:42 PM   #9
ChuckPink
2008 KK Liberty
I have an 05' with stock 3.73 gears and 31's and I have always gotten 15 MPG consistently........Drives me nuts. Plus almost 90% of my driving is highway miles.
ChuckPink is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 02:49 PM   #10
bottlerocket91
The 6 speed manual isnt much better than the 5 speed as far as the overdrive goes. Just has a taller first gear
bottlerocket91 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 03:48 PM   #11
j_niko
2009 JK Wrangler
My 2000 with 4.0l and 33s - 12 MpG
97 with 4.0l and 31s - 16 MpG
My 2010 Challenger R/T with a 5.7l hemi - 25.5 MpG
I still can't reason that one out......
2000 - Sahara
1997 - Sahara
j_niko is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 04:04 PM   #12
bottlerocket91
Doesnt the 2010 have the engine that runs on 4cyl on the hwy? Also it doesnt have the aerodynamics of a barn
Unread 11-10-2010, 04:55 PM   #13
chris142
My 02 sure seems gutless compared to older TJ's and YJ's that my customers bring in. I bet their mpg is better than mine too.
chris142 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 05:10 PM   #14
terpsmandan
2009 JK Wrangler
05 with 3.73 and a 6sp and I get between 16 and 18 mostly highway.
terpsmandan is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 05:16 PM   #15
Knight-Rider
My 99 swb with a 4.0l and a 5 speed and 31's. I used to get 25 mpg no matter where I went city or hwy.
My 06 LJ rubi with an auto and 31 's. I can get 19 mpg. if I get on a flat stretch and use the cruise control. around town, it ranges all the way down to 10mpg.
Knight-Rider is offline   Reply With Quote Quick reply to this message
emission , miles per gallon , mpg , tj
