Mileage dropped, should I be concerned?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
My gas mileage had been staying pretty steady at around 17-19 MPG, but the last month or two it is 14 not matter what. I am getting right at 14 no matter if I drive highway or city and with or without heat. If anything, it is worse on the highway.
Does this sound familiar to anyone? Should I get it checked out? It actually started right around when I replaced the stock gas cap, certainly that is just a coincidence though. Thanks.
2005 Wrangler Willys Edition Bought: 10/6/07 Stock [URL="http://www2.snapfish.com/share/p=71771191779458120/l=306339670/g=107825866/cobrandOid=1000131/otsc=SYE/otsi=SALB"]Check Out My TJ Willys[/URL] |
#2 |
What was wrong with the stock gas cap? You might be getting ready for a check engine light to come on. That's usually a sign that the computer might be on to a problem.
-Ross 1998 Subaru Forester DD 2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy 1987 Coleman Columbia 3/4 ton+ tow rig wanted! |
#3 |
Perhaps a silly question, but have you checked your tire pressure? I got lax and discovered mine were down to 20psi (even though they didn't look it) and once I put them back up to 28psi it's like a new Jeep!
2005 Unlimited, 4.0L, 4sp auto, 3.73 stock gears, BDS 3" lift w/ 3/4" Daystar coil spacers up front, BDS front adjustable trackbar, BDS 5500 shocks, Rough Country X-Flex lower control arms, JKS 1.25" body lift, JKS BMML, AR Outlaw II 15x8 wheels, BFG AT 33x12.5 tires, AtoZ rocker guards, Rokmen belly-up transfer case skid, homemade 1.5" gas tank lift |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
