Quantcast MetalCloak Clearance Diagrams... MetalCloak vs. Others - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > MetalCloak Clearance Diagrams... MetalCloak vs. Others
Old 08-25-2009, 05:17 PM   #31
ZeRrk
If you look at the pictures Firekite posted, you'll notice that it's not just the flare that the MetalCloak replaces, but the entire fender... So the inner fender won't be a problem. In other words, this doesn't look like a bolt on upgrade.
ZeRrk is offline   Reply With Quote
Old 08-25-2009, 06:27 PM   #32
bebout
Originally Posted by matsonian View Post
On a cursory glance at your rig, I still think you would gain clearance. If you profile is current you have a 2" lift on 35s... and even though your fender is modified (looks sweet) you still gain at both the top of the tire and the back against the tub.
You can see in this side diagram (looking down axle) vs. a typical tube fender the clearance we gain both at the top and back.
The extra opening wouldn't be a bad thing. I will definately look into them after I get my tires. Thanks.
bebout is offline   Reply With Quote
Old 08-25-2009, 06:29 PM   #33
6thelement
it replaces the intire fender,relocats batt,washer res,and will give alot more clearnce over flat fenders .next to the hiline fenders i think they are close to the same opening.
if at first ya don't succeed .don't tell anyone
6thelement is offline   Reply With Quote
Old 08-25-2009, 06:51 PM   #34
bebout
The more I look at the pics of them posted the more I like them. What is the little silver panel made of tho?
Old 08-25-2009, 10:19 PM   #35
Jeepineer
11 gauge T304 Stainless Steel with a single direction surface ground finish. It is an access panel for ease of assembly.
Jeepineer is offline   Reply With Quote
Old 08-25-2009, 10:27 PM   #36
bebout
I checked out the site, and I'll be getting a set of these without the flare.
Old 08-25-2009, 10:30 PM   #37
Kenbo-Slice
" Volkswagen "
Kenbo-Slice's Avatar
Well Mattsonian, I must say I think I am back to being a fan. You came through with the diagrams, and the pictures really did them justice. Aluminum would be great, and although I still feel that the price is a bit high, I could see myself running them.
Jeep build up...ONGOING Jeep build up...ONGOING
R.I.P. Tow Pig Dually build
Rear bumper/spare tire carrier build
Track bar bracket fabrication
AtoZ cage install/build
NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles!
Kenbo-Slice is offline   Reply With Quote
Old 08-25-2009, 10:32 PM   #38
Jeepineer
Your comments are correct about the inner fender well being replaced entirely. However this is a true bolt on system. You completely unbolt your stock fender with no damage at all (stock fenders can even be resold). Then you bolt on the system where the stock fenders were removed using the stock fastener hardware.
Old 08-25-2009, 11:45 PM   #39
StormTrooper05
http://photos3.meetupstatic.com/photos/member/1/f/0/0/highres_7447936.jpeg
StormTrooper05 is offline   Reply With Quote
Old 08-26-2009, 12:12 AM   #40
wrangler2007
Aren't the metal cloak's the same that are on Teal-J in one of the magazines?
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 08-26-2009, 12:28 AM   #41
StormTrooper05
I have Metalcloak fenders on my TJ with no lift and 35 inch tires and they do not rub at all. I have a few critiques of the fenders but would certainly buy again.
Old 08-26-2009, 12:29 AM   #42
matsonian
MetalCloak'd
matsonian's Avatar
Yes, the Teal-J, now known as the Teal Brute, has our fenders. You can see it on the cover of the July issue of Four Wheeler.
matsonian is offline   Reply With Quote
Old 08-26-2009, 12:36 AM   #43
matsonian
MetalCloak'd
matsonian's Avatar
Originally Posted by StormTrooper05 View Post
Great pic, 35s on No Lift... thanks for posting!
Old 08-26-2009, 12:57 AM   #44
bebout
Making me want them even more. Very nice rig.
Old 08-26-2009, 01:13 AM   #45
StormTrooper05
Thanks. Just to clarify I have no suspension lift. I do have a 1inch body lift. But that's it.
Glock Forum
