metal ring with new Autolite spark plugs???? - JeepForum.com
post #1 of 13 Old 01-28-2010, 04:01 PM Thread Starter
purplepig
my new Autolite APP 985 plugs came with a metal ring. I have never seen this before. Is it some type of gasket I am supposed to use??????
purplepig is offline
post #2 of 13 Old 01-28-2010, 04:02 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
yes. its a lock washer.
Mail crawling.
MisfitSeven is offline
post #3 of 13 Old 01-28-2010, 04:05 PM Thread Starter
purplepig
ok thanks!
post #4 of 13 Old 01-28-2010, 04:18 PM
lumpster
lumpster's Avatar
i thinks a crush washer, to seal up. not a lock washer, why would you want to lock your plugs in?? Ive never had a spark plug back out.
lumpster is offline
post #5 of 13 Old 01-28-2010, 05:02 PM Thread Starter
purplepig
That makes sense. I was kind of wondering because I can't see how a spark plug would just come out.
post #6 of 13 Old 09-13-2010, 08:15 AM
sumday
which way are you supposed to install the washer?
sumday is offline
post #7 of 13 Old 12-01-2011, 11:56 AM
Deepair3
Which way does the washer go in? Or does it matter?
Deepair3 is offline
post #8 of 13 Old 12-01-2011, 11:59 AM
2005-TJ
1983 CJ7
i did mine this past weekend and put the flat side toward the plug
2005-TJ is offline
post #9 of 13 Old 12-01-2011, 12:00 PM
mdm
Farm Wheeler
Between the plug and the head works for me. It's a simple crush seal, don't over think it.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #10 of 13 Old 12-01-2011, 12:14 PM
2005-TJ
1983 CJ7
i just called Autolite and they said they can go on either way, but their preference would be for the larger/flatter end to go toward the plug. Hope this helps ya out!
2005-TJ is offline
post #11 of 13 Old 12-01-2011, 12:25 PM
Deepair3
That's kind of what I figured. Thanks for the info!
Deepair3 is offline
post #12 of 13 Old 12-01-2011, 12:30 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I recently learned its a larger problem on aluminum head engines. A friend of mine blew a plug out of a Ford 5.4 Tritan engine ~2 weeks ago...plug backed out till it finally ripped all the threads out of the aluminum head on a compression stroke, while driving down a country road . His mechanic found three others about to go. apparently the cause is heat cycling + improper plug torque + no loctite...and Ford makes a heli-coil specifically for this issue. so...torque your plugs to spec!
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #13 of 13 Old 12-01-2011, 12:36 PM
mdm
Farm Wheeler
Aluminum heads can cause loose plugs if you don't stay on top of them. I had a '74 VW in Alaska. There were a lot of Bugs up there but most of them got parked in the winter. I couldn't park mine. The aluminum heads and steel jugs did the same thing. Different heating/cooling rates caused the head bolts to loosen. I had to torque them down about once a week.
mdm is offline
Sputtering with Autolite AP985 spark plugs little_chuck TJ Wrangler Technical Forum 30 04-06-2013 05:25 PM
Autolite spark plugs? TJforlife TJ Wrangler Technical Forum 10 12-12-2006 12:44 PM
Autolite XP spark plugs Grimmjpr TJ Wrangler Technical Forum 0 08-29-2006 06:57 AM
autolite plugs ok to use on a 95 4 banger? fatboyq YJ Wrangler Technical Forum 5 04-27-2006 03:47 PM
Autolite spark plugs NewLaw83 TJ Wrangler Technical Forum 6 03-23-2006 06:00 PM
