Quantcast Mechanic says the radiator is fine, but... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Mechanic says the radiator is fine, but...
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 03-12-2008, 06:09 PM   #1
dreynolds_500
So, I've got an 02 with 70K miles on it that has a thirst for antifreeze. Based on the research I was able to do on the forum, I narrowed it down to either a radiator leak or an engine block leak (bad head gasket). Armed with this knowledge, I took it to my mechanic for a pressure check to determine if it was a simple rad replacement or something much more expensive. After testing it for several hours, he came back and said the rad is holding pressure and the engine block passed its test too (carbon, no coolant in the oil, no smoke from the tailpipe, no coolant in the tranny).
I'm filling up my reservoir every 2 or 3 days ( it's my DD and I drive ~50 miles a day on backroads). If I run on the interstate, I'm refilling after about 2-3 hours of driving. When parked, there are no visible leaks under the Jeep, but you can smell coolant when driving (stopped at a light, etc.).
Does anyone have any ideas? I don't want to replace the rad just for the sake of replacing it, but I will if I have to. Thanks in advance for your help!
dreynolds_500 is offline   Reply With Quote
Old 03-12-2008, 06:16 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Did he use a "sniffer" to look for the presence of combustion or exhaust related gasses in the coolant? A test strip can do the same thing, they test the coolant via the radiator cap's opening.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-12-2008, 06:26 PM   #3
HipCheck_1
Sounds like a possible leak in the heater core.
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline   Reply With Quote
Old 03-12-2008, 06:29 PM   #4
dreynolds_500
He did do the sniffer test (according to him). How do I check to see if there is a leak in the heater core?
Old 03-12-2008, 06:32 PM   #5
HipCheck_1
I am not sure how to check it on the Jeep but I had a '97 eclipse with a bad heater core.
The windshield would fog up all the time, could smell the coolant, and started seeing coagulated coolant on the carpet in the passenger side by the firewall.
Old 03-12-2008, 06:58 PM   #6
tjthorson
tjthorson's Avatar
It may hold pressure when cool. Under heat and pressure, you may have a leak.
Check for antifreeze crust under the waterpump. There is a weep hole that will start to leak when the seal is wearing out.
Also look for crusties around the tank clamps, hoses, etc.
Todd Thorson
2005 Yellow Unlimited Rubicon 4" front springs, Caprice Wagon CC623 (3.5") rear springs, BL, BMML, Rokmen TT, SJ Hydros
Yellow Jeep Club Member #4
http://www.toddsplace.com
tjthorson is offline   Reply With Quote
Old 03-12-2008, 07:04 PM   #7
mcg311TJ
I'm guessing it's a stock rad?
mcg311TJ is offline   Reply With Quote
Old 03-12-2008, 07:32 PM   #8
dreynolds_500
Yup, it's a stock rad - I know they're prone to fail right around now. As far as crustys, I'm not seeing any. I know he tested my rad when it was hot b/c the car was hot when I picked it up and watched them pull it out of the bay.
Please keep asking questions and throwing out ideas - I just want this fixed before summer (traffic + heat+ bad rad = towtruck).
Old 03-12-2008, 07:35 PM   #9
1BadJeepX06
Had a chevy with the same problem... Heater core fixed the problem... :my2c
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline   Reply With Quote
Old 03-12-2008, 07:40 PM   #10
dreynolds_500
If the heater core were bad, would I still have hot air coming out? The heater works like a champ - gets nice and toasty in there!
Old 03-12-2008, 08:12 PM   #11
cj847
If the heater core is leaking you should get some dampness in the passenger foot area (damp carpet, etc).
Based on the age/mileage I would be saving up for replacement parts even if they are good right now.
Has the jeep ever actually overheated? You mentioned a thirst for antifreeze - if you overfill it, it will push that antifreeze out when hot (ie it you continually refill your overflow bottle, it will continually go down to a certain level). I would suggest keeping a gallon of 50/50 in your jeep and drive it until it actually starts to heat beyond normal before adding more antifreeze.
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline   Reply With Quote
Old 03-12-2008, 08:25 PM   #12
dreynolds_500
I've never run it until it overheated. However, when I fill the overflow bottle to the 'Full' line, I've let it run until it's completely bone dry in there - about 3.5 days. At that time, I fill it back up b/c I don't want to be "that guy" on the road blocking traffic because my rad overheated.
I'll check for dampness on the pass. side and see if there is any.
Old 03-12-2008, 08:33 PM   #13
tjthorson
tjthorson's Avatar
It would still work - but to be leaking as much as you say - it would be getting oily residue on the window, smelling real strong, and fogging the windows constantly as it atomized the antifreeze.
I would add a UV dye to the overflow and radiator and get one of those UV penlights. You will find it.
If you absolutely dont - its burning it somewhere then internally and its time to pull the head.
Its not doing it because it doesnt like you. The antifreeze is going somewhere....
Todd Thorson
Old 03-12-2008, 08:40 PM   #14
dreynolds_500
OK - 1) Where do I get a UV dye? 2) Where do I add the dye (overflow or rad)? 3) I assume that means running it in the dark? What's a safe way to close a garage and vent out the fumes? 4) Are you positive it doesn't mean it just doesn't like me?
Old 03-12-2008, 08:49 PM   #15
JFM626
Senior(not yet 65)Member
You can eliminate the heater core if you don't mind being a little cool for a couple of days. Remove the heater hoses where they go into the heater at the firewall, and join them together. This will put the heater core out of the equation. If you now continue to lose coolant, well it won't be the heater core will it. If you don't lose any more coolant, best to put a weekend aside to change out that heater core. Without going outside to look, I seem to remember that the heater hoses are different sizes 5/8 and 3/4???
JFM626 is offline   Reply With Quote
Glock Forum
