Measuring for Double Cardan Drive Shaft - JeepForum.com
post #1 of 6 Old 01-04-2006, 08:36 AM Thread Starter
dojohnso
Folks,
Can you give me some insight as to when to measure the length of the driveshaft. Do I wait until I do the lift, or can I measure now and order?
Im going with the OME 2.5 and JKS BL and MORE MML.
05 SOLAR YELLOW TJ Rubicon
Yellow Jeep Club Member #1102
I've got a few cool add ons.
dojohnso is offline
post #2 of 6 Old 01-04-2006, 08:53 AM
RubiconSS
RubiconSS's Avatar
It's from flat spot on the back of the transfer case (as if the DS was off) TO flat spots on the front of the rear diff yoke.
I believe it measures about 16 1/4". When you call TW or a vendor, they will go by expected lift up to 6" and over 6".
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline
post #3 of 6 Old 01-04-2006, 08:55 AM Thread Starter
dojohnso
Cool. THX! Just want to have everything here and ready to bolt in when the time comes.
dojohnso is offline
post #4 of 6 Old 01-04-2006, 08:58 AM
RubiconSS
RubiconSS's Avatar
If you call TW, you will find them very helpful. I actually s/w Tom Woods, the day I called He answered the phone.
You will be impressed by the product. Very well made.
post #5 of 6 Old 01-04-2006, 09:32 AM
tonkaJP
may not even need to do SYE and new DS with the MML ......might have to add a couple washer under the TC skid. every jeeps different though.
06 Khaki Rubicon Unlimited......work in progress
tonkaJP is offline
post #6 of 6 Old 01-04-2006, 10:07 AM Thread Starter
dojohnso
RubiconSS, Thanks for the tip. Ill follow that guidance.
tonkaJP: I dont want to do my lift, find out I have vibes, then have to wait weeks for a Driveshaft. I tend to error on the conservative side, and money to me isnt the issue. I just want to be ready with everything, and also have the flexibility and future ability to just add in a TT.
Thanks both for your replies!
D
dojohnso is offline
Double Cardan Vs. Cv Drive Shaft n8tmi TJ Wrangler Technical Forum 41 06-27-2012 05:09 PM
Can you make a Double Cardan drive shaft? KJFactor YJ Wrangler Technical Forum 5 08-21-2009 05:46 PM
single cardan vs. double cardan u-joint? Adjustable track bar compatibility? Mr. Tarmac TJ Wrangler Technical Forum 1 03-03-2007 11:43 PM
Double cardan drive shafts? skenzer TJ Wrangler Technical Forum 4 08-15-2005 08:44 AM
Double cardan type drive shaft without SYE? Baas TJ Wrangler Technical Forum 18 09-03-2004 10:48 AM
