MBRP S5500409 Stainless Cat-back Kit - No noticeable sound increase? - JeepForum.com
post #1 of 8 Old 06-19-2017, 06:41 AM Thread Starter
Sawchy
Hey all,
I recently installed an MBRP S5000409 2.5" Cat-back exhaust with a 3.5" tip onto my 2003 TJ Sport, automatic. After reading many reviews on it, as to the increased throttle response and a little better MPG from some, I decided to give it a try. However, after watching some videos and listening to how it SHOULD sound, mine sounds nothing like it. Maybe a TINY bit louder than stock, but only from the tip. Any suggestions as to why it may not be sounding as it should?
Sawchy is offline
post #2 of 8 Old 06-19-2017, 07:16 AM
CGrugger
CGrugger's Avatar
In my experience with exhaust on other vehicles. They will sound a bit different after they get broken in.
Also, in those videos, did they also have aftermarket intakes? That would increase the sound.
Sent from my SM-G935V using Tapatalk
2005 TJ X: 2" RE spacer lift, 32"x11.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is online now
post #3 of 8 Old 06-19-2017, 07:24 AM Thread Starter
Sawchy
So it may just take some time to have the true rumble come out? Some did, some didn't. I also have a K&N Cold-Air intake installed as well.
Sawchy is offline
post #4 of 8 Old 06-19-2017, 07:35 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #5 of 8 Old 06-19-2017, 09:57 AM
CGrugger
CGrugger's Avatar
Possibly. I would think you would heat an increase over stock.
I only had put other exhaust on my CJ, and heard a difference with each one. Never put one on the tj
post #6 of 8 Old 06-19-2017, 01:31 PM
Mattific
Also did you weld or clamp the system into place? That will make some difference too.
Mattific is offline
post #7 of 8 Old 06-19-2017, 01:35 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
All this is why I have consistently advised folks to avoid mail-order cat-backs. When you buy and have it installed locally, there's no problem getting exactly what you want.
Jerry Bransford is online now
post #8 of 8 Old 06-19-2017, 02:07 PM
Kgleiss05
Kgleiss05's Avatar
I had this exhaust on my 04 Rubicon and I loved its sound. Had a nice rumble to it, not to loud to be obnoxious. Plan on getting it for my LJ while they have the discount going.
Is it possible your old system was worn out and was louder than it should have been?
06 LJR, Jeep green, hardtop, 6 spd, 3.5" springs, JKS front track bar, RE lower control arms, bilstein shocks.
Kgleiss05 is offline
