Max. Flex vs. Useful Flex and The Anti-rock - Page 3 - JeepForum.com
post #31 of 35 Old 05-17-2007, 02:37 PM
fyrfyter43
fyrfyter43's Avatar
Originally Posted by lupinsea
Dang, that's too bad.
Well, after about 2 years the heim joints on my anit-rock are wearing out and need to be replaced. I may pick up the supplies from McMaster Carr including $4 in the threaded rod and jsut make some new links instead of trying to find "just the right" 20 pitch heim joint.
Or you could always just get the heims from McMaster-Carr.
1/2" - 20 heim joints, female shank, greasable.
RH thread: p/n 4444T231 $6.98
LH thread: p/n 4444T232 $6.98
Click!
fyrfyter43 is offline
post #32 of 35 Old 07-31-2007, 12:56 PM Thread Starter
lupinsea
lupinsea's Avatar
I ended up upgrading to the SwayLOC. Damn, it's an awesome piece of equipment. The Anti-rock is good but having the second stiffer torsion rod for the street setting is great. TJ corners really flat now. And switching between onroad and offroad takes about 2 seconds and a flip of a lever.
- Jay
lupinsea is offline
post #33 of 35 Old 12-27-2007, 06:31 AM
flexytj79
just fitted my antirock 2 weeks ago , so much better to drive on and off road
now
Originally Posted by ram1500dodge View Post
holy bejesus, look at the size of that winch hook
Originally Posted by bmlawless View Post
This should be interesting. Aussies always come up with the best stories.....
Originally Posted by Rubicon 05 LJ View Post
Better yet, why are you looking at the hook??
shes cute an all, but man, if my hook looked like that hook, id never let it out of my sight.
flexytj79 is offline
post #34 of 35 Old 01-08-2008, 07:20 PM
kenskis
I like the explanation, it explains off-road sway bars well. However if you have locking differentials wouldn't you want maximum flex to try and have a level body for you Jeep, while the suspension does all the flexing. I can see that one tire might have very little down force, and thus little traction, but with lockers the other tire should be able to have adequate traction. Am I wrong?
|______
|l ,[____],
l---L OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #35 of 35 Old 10-29-2008, 11:03 AM
hoot20
i have no flex and i'm really wanting to get this but could someone answer this?
- i have a 2.5" coild spacer and a 2" body..... could the anti-rock be installed easily?
- does the anti-rock drive good on the road?
2000 TJ sport "STORMTROOPER" dual tops, 4.0L, 2.5" coil spacer, 2" BL, jks quicker disconnects, worn out 35x12.50 bfg M/Ts, 15x8 d window rock crawlers w/ 4" backspacing, front stinger, custom rear bumper, superwinch lp8500 winch, a to z rocker guards, husky liner floor mats, CB/PA system, daylighters, and straight exhaust
Originally Posted by boone78 View Post
jeeps don't stuck, they just take breaks every once in a while, in deep holes.
Originally Posted by Prot View Post
Dirty Deeds, Done With Jeep!:duhrock:
hoot20 is offline
Rancho 3.5 rock Krawler, RE 3.5 Super Flex, New RC 4? slafferty TJ Wrangler Technical Forum 3 08-30-2009 09:48 PM
YJ Flex YJ_95 YJ Wrangler Technical Forum 7 04-20-2008 10:51 PM
flex fan claytonandson TJ Wrangler Technical Forum 4 07-02-2007 10:56 AM
more flex!!! iwishihad1 YJ Wrangler Technical Forum 23 02-09-2007 04:46 PM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 09:01 PM
