Manual Transmission drain/fill plugs - JeepForum.com
post #1 of 5 Old 01-01-2004, 09:11 PM Thread Starter
Pinebarrensboy
I was under my jeep the other day, and was going to check my trans fluid, but I noticed the fill and drain plugs have octagon shaped fittings, and not the usual square shape which the front and rear differentials use, which you can use regular ratchets to loosen. Any one have any idea what I can use to get them loose???
Brandon
2003 Rubicon
2.25" Budget Boost / Skyjacker 7000 Hydros
265/75/R16 Goodyear Wrangler MT/R's
JKS Quicker Disconnects
Pinebarrensboy is offline
post #2 of 5 Old 01-01-2004, 09:31 PM
macb
macb's Avatar
2014 JK Wrangler
17mm hex key, sears has em for about $8-$10 I think.
or you can use a bolt the right size with a few nuts on it to form an insert so you can use your 17mm socket.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #3 of 5 Old 01-02-2004, 01:10 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Are you sure you're talking about the tranny and not the transfer case? My AX-15 tranny has hex-head bolts for the drain and fill holes. What year and model Jeep do you have?
Jerry Bransford is offline
post #4 of 5 Old 01-02-2004, 07:52 AM
Owen
Owen's Avatar
Jerry he has the NV3550. It has the drain fill plugs he is talking about... I know because I also have that tranny.
I carry a bolt with countersunk nuts on it to get them out. Beats spending $10 for an allen key I will use once in a blue moon or lose.... it cost me less than a dollar and I can use a regular open ended wrench on the bolt to get the plugs in and out.
Smuggler Re-Born.....
Owen is offline
post #5 of 5 Old 01-03-2004, 05:48 PM Thread Starter
Pinebarrensboy
Thanks for the replies guys....well it turns out I needed to get a 17mm hex that I could use on a 3/8's ratchet. I looked around a few stores, and could not find one that size, the biggest they had was 10mm. I decided to go to the hardware store, and took a 17mm x 2 inch bolt, and screwed on two nuts, with this other kind of nut in the center which is fat on one side, and skinny on the other (I'm not sure of the name of this). This seems to work well, I was able to use my 3/8's ratchet with a spark plug socket and fitted the bolt on, it fit perfectlly into the hex fittings on the transmission, and I was able to get them out easily. I wish I could get a photo up here for the others to see, I think I spent only a $1.50 or so when everything was said and done, certainly worth the small investment.
Brandon
2003 Rubicon
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 04:26 AM
manual tranny drain and fill plugs bobjp TJ Wrangler Technical Forum 5 07-01-2006 11:06 AM
Size of drain/fill bolt on a Manual transmission for 2000 TJ dsyJeep TJ Wrangler Technical Forum 3 06-10-2003 07:28 AM
2002 manual transmission drain/fill canuck75 TJ Wrangler Technical Forum 11 05-31-2003 06:10 PM
removing fill and drain plugs on manual transmission 02 PaMuddin TJ Wrangler Technical Forum 2 03-26-2003 11:50 AM
