Manual Tranny Shifter Issues with Body Lift? - JeepForum.com
post #1 of 5 Old 04-28-2010, 06:47 AM Thread Starter
elcidsurfer
Im thinkin about puttin a 1" body lift on my TJ. A have the six speed manual tranny and when I put my 1.25" TCase lowering kit on with my lift I could not shift into Reverse because my stick hit the boot ring. I ended up not using my TCase lowering kit because of this. If I throw a 1" body lift on will the same thing happen because its basically creating close to the same separation from the Tranny and the body. Thanks.
elcidsurfer is offline
post #2 of 5 Old 04-28-2010, 07:26 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
Did you use a MML instead of the t case lowering kit? If not,now would be a good time to do it with the BL and no shifting problems.I just did that to my brother's 05' with a 4" lift.You can also move the console back 1/2".
TheBoogieman is offline
post #3 of 5 Old 04-28-2010, 08:34 AM
-dirt-
I put a 1" PA BL on my '05 with the 6-speed and experienced shifting issues in the rear gears (mainly reverse). To alleviate this, I pulled the boot and it shifts fine with that popped loose. When I added a 1" MML, the shifter was still too close to the console and the boot wouldn't let reverse fully engage.
I added a UCF tummy tuck, and that really brought everything up back where it should be/where I like it. Shifted created and full gear engagement. But the TT created a whole other set of issues.
So to answer your question, from my experience: Yes, you do run the risk of the shifter hitting the boot ring with a 1" BL.
-dirt- is offline
post #4 of 5 Old 04-28-2010, 08:49 AM
orchimaxi
I have the 5 spd, and my experience is that after a 1.25" BL my shifting was tight in the "rear" gears but were fixed with a tummy tuck skid and a MML which I installed a few hours later. I expect that the TT will mean that when I do lift the Jeep (once I get my $400 ZJ road worthy) I will need to do a SYE/driveshaft to eliminate my anticipated vibes.
1999 XJ SE 5 spd 4.0 -- Dead
2001 TJ Sahara 5 spd 4.0 -- Sold
1995 ZJ 5.2L -- Sold
1997 TJ 4 cyl 5 spd - still figuring it out...
orchimaxi is offline
post #5 of 5 Old 04-28-2010, 03:14 PM Thread Starter
elcidsurfer
Thanks fellas, that helped out alot.
TJ manual shifter hit console after body lift cowboy1107 TJ Wrangler Technical Forum 13 08-30-2009 05:53 PM
99 TJ Manual Tranny Issues GunMetalBlue TJ Wrangler Technical Forum 7 01-19-2009 07:30 PM
Manual Tranny Shifter Question. Niceface TJ Wrangler Technical Forum 2 10-08-2008 09:08 PM
Body Lift and Hurst shifter tomkirkland4 TJ Wrangler Technical Forum 2 06-16-2005 06:07 PM
B&m shifter, Will it work with body lift norm33 TJ Wrangler Technical Forum 1 10-01-2002 01:31 AM
