manual tranny drain plug removal Q? - JeepForum.com
post #1 of 11 Old 09-07-2003, 07:20 PM Thread Starter
PADI_Pro
Ok, went to check all the fluid levels on the used TJ I bought a while back. Got everything checked except the 5 spd. tranny. What size hex head do I need to get the plug out?? My brother is a farmer with more tools than god, but nothing big enough to get this plug. So, I guess a trip to Sears is in order, but would like to know the size first.
Thanks.
'01 TJ Sport Metallic Silver
Stock 5 spd. I6 with a D44 rear
Savin' up for the mods.
PADI_Pro is offline
post #2 of 11 Old 09-07-2003, 07:53 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You sure you're talking about the tranny? It sounds like you're looking at the transfer case. The tranny drain and fill plugs are on the side of the tranny which is in front of the transfer case whle the transfer case is to the rear of the transmission, with the big drain and fill plugs facing the rear axle.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is offline
post #3 of 11 Old 09-07-2003, 09:11 PM
flip2spin
i feel your pain
i had to make something to fit mine
i used a old bolt grinded it to make it fit in there and then welded a nut on the other side and it came right out
i think its a 12-14 millimeter some where it that range
but i dont remember
flip2spin is offline
post #4 of 11 Old 09-07-2003, 09:21 PM Thread Starter
PADI_Pro
Jerry, I'm sure it's the tranny. Large drain plug, forward of the transfer case skid plate, on the drivers side. 'Bout halfway up the tranny. Hope someone out there knows, else I'll have to do some testing at Sears.
PADI_Pro is offline
post #5 of 11 Old 09-07-2003, 09:33 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Look again, there are some fake looking bolts around there. Once at midnight I learned this...
K9Jeep
K9JEEP is offline
post #6 of 11 Old 09-07-2003, 09:48 PM
Jerry Bransford
Administrator
You still might not be looking at the drain plug. Look near the bottom on the side of the tranny for a smaller hex-head bolt, in the forward section. No drain plug would be half-way up the side of the case.
post #7 of 11 Old 09-07-2003, 09:53 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Originally Posted by Jerry Bransford
... No drain plug would be half-way up the side of the case.
But the fill plug would be... I'd hope by now he found something that obvious on the bottom, even in the dark.
K9Jeep
K9JEEP is offline
post #8 of 11 Old 09-07-2003, 09:58 PM
surfzup2k
surfzup2k's Avatar
EDIT didn't realize he didnt have an ax-15 until i looked at his sig
1995 YJ 4x4 4.0 5-Speed
35x14.50x15 SS Terdbirds
4" Skyjacker lift
2" hd shackles
locked 8.8 Rearend
4.56's
cut fender flares
pics...
color="white">White Jeep Club Member #112
surfzup2k is offline
post #9 of 11 Old 09-07-2003, 10:12 PM
Jerry Bransford
Administrator
Lookee what I found. http://www.4x4xplor.com/trannyservice.html
post #10 of 11 Old 09-08-2003, 08:25 AM Thread Starter
PADI_Pro
Thanks Jerry, it's a 17mm by that site. If you look at their picture with the arrows, the plug I needed to remove to check the level is the fill bolt - roughly halfway up the side of the tranny on the drivers side.
Thanks for the help.
PADI_Pro is offline
post #11 of 11 Old 09-08-2003, 08:57 AM
Owen
Owen's Avatar
I bought a bolt and counter sunk two nuts on it. Way cheaper than buying a hex that size. I keep it in my center console... I use it all the time...
Smuggler Re-Born.....
Owen is offline
Drain Plug Removal with Pics! SpydermanTJ TJ Wrangler Technical Forum 36 09-27-2014 02:09 PM
Manual transmission drain plug..? fishmanwill YJ Wrangler Technical Forum 8 01-14-2013 10:15 AM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
4.2L Block Drain Plug Removal - tool? Delta347 YJ Wrangler Technical Forum 0 12-29-2008 01:05 PM
Drain plug for ax-5 tranny freeballer YJ Wrangler Technical Forum 3 11-09-2004 03:59 PM
