Manifold for beginners - JeepForum.com
post #1 of 47 Old 04-27-2010, 03:09 PM Thread Starter
TheBeast
I removed my exhaust manifold this weekend to replace what I thought was a bad gasket. Turns out to be a crack on the OEM manifold. So now I'm thinking might as well upgrade to headers instead. What is everyone getting as replacement?
TheBeast is offline
post #2 of 47 Old 04-27-2010, 03:14 PM
USMC_XJ
2003 WJ
I got another stock one off Ebay. $82 withe free shipping. I have always made sure to get the extended things in the tubing like the OEM's have. The aftermarket headers don't have these, and are prone to cracking too.
The one I replaced on my dads 97 TJ has been fine for 2 years and I just replaced mine on my 94 XJ about 3 months ago. All is good.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #3 of 47 Old 04-27-2010, 03:16 PM
jerseyjeep22
how hard are they to take off/get back on? I have a crack in my manifold and I haven't dealt with it yet
jerseyjeep22 is offline
post #4 of 47 Old 04-27-2010, 03:19 PM
JCWJEEP
2010 JK Wrangler
The OEM manifold is just as good as any aftermarket header. A lot of people just go with the ebay replacements with the flexible fittings. The cracking is caused by warping and flexing created by the heat the pipe goes under and combine that with the length of the header and it's bad. It seems that the units with the flex tubing help alleviate this problem some but eventually it'll happen. The aftermarket headers don't have that feature and are more likely to crack.
Or you could have that crack repaired and then run it until it breaks again.
JC Whitney Jeep Team
JCWJEEP is offline
post #5 of 47 Old 04-27-2010, 03:21 PM
purplepig
I am happy with the Banks that was installed by the PO years ago. I would check for the best warranty.
purplepig is offline
post #6 of 47 Old 04-27-2010, 03:51 PM
TJ311
I agree that it actually looks like a half way decent design for a stock manifold. I'd say if you got an aftermarket one, make it a stainless header AND add a small piece of flex pipe somewhere after the flange.
TJ311 is offline
post #7 of 47 Old 04-27-2010, 04:28 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Get an OEM 2 piece manifold for the 2000 and newer 4.0L. Have a "Y" pipe made at an exhaust shop. It's the best setup you can do for pre 2000 4.0L engines...
Knuckelhead is offline
post #8 of 47 Old 04-27-2010, 06:11 PM Thread Starter
TheBeast
Ok, I have a 99 so 2-piece is not an option. Looks like majority are just stock aftermarket manifolds. Some are Borlans, Banks, etc. I checked Autozone and they have Dorman for $188, 1yr warranty. Then I checked Checker's and they have Dorman also for $260, lifetime warranty. Both comes with the gasket already. I think I'll just get the Checker's. I took a lot of pics (one reason why it took me 5 hours to remove it plus I'm a newbie at this). I'll post my write up here later.
TheBeast is offline
post #9 of 47 Old 04-27-2010, 06:34 PM
tjsean0308
I think Knuckelhead meant that for about the same money at the exhaust shop and a trip to the "you pick it" for a two piece manifold, you could have a possibly more permanent solution. welcome to the 4.0 they all crack like that, the motor is so long and the manifold heat cycles so much. Even mine on the 4cyl cracked. I went with the banks (one of very few 4cyl options) been good for two years now.
best of luck.
tjsean0308 is offline
post #10 of 47 Old 04-27-2010, 06:38 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
why do you think that?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 47 Old 04-27-2010, 07:11 PM
Knuckelhead
AFSOC Retired
The option is there for you, use it...
post #12 of 47 Old 04-27-2010, 07:30 PM
Rcajun
I gotta an extra 2 piece laying around if your interested.
Rcajun is offline
post #13 of 47 Old 04-27-2010, 08:45 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
that crack does look repairable, if you are looking for the cheapest route.
Mail crawling.
MisfitSeven is offline
post #14 of 47 Old 04-27-2010, 10:07 PM Thread Starter
TheBeast
Thanks for all the suggestions. I re-read Knucklehead's post and I misunderstood. I don't want to go cheap and just patch things up but I also don't want to be too different that I have to take extra steps to get or install the parts I need. Changing the manifold is not something I'm comfortable of doing. I'm just a newbie in both the Jeep world and doing something very extensive like this. Baby steps for now.
TheBeast is offline
post #15 of 47 Old 04-27-2010, 10:56 PM
uvalax236
Banks has a lifetime warrantee. Im on my second header from them. First one lasted 3 years...lets see how long this one lasts.
06 Solar Yellow AT
Banks Headers, ARB Periscope, Clayton LA/TT,
Coast 1350 Shaft, JKS BL/BMML/Quicker Discos/Adj BumpStops,
RE 4.5 Springs/BrakeLines/HD TB, Currie Steering, VVME 3000k, 6000k HID Systems, IPF H4 Headlights,
315/75/16 Nitto Terra Grapplers on Moab's, 5.13's and TruSpeed
uvalax236 is offline
Changing intake manifold and exhaust manifold Gaskets Cards89YJ YJ Wrangler Technical Forum 17 01-13-2012 04:32 PM
Does this sound like an alright beginners set up? TOLjeep TJ Wrangler Technical Forum 17 08-28-2008 06:28 AM
Beginners cost guide to modding sromain JK Wrangler Technical Forum 15 07-21-2008 10:24 AM
could this be the manifold? drummerwookie TJ Wrangler Technical Forum 6 02-12-2007 06:48 PM
i think its the manifold... paroxysym TJ Wrangler Technical Forum 2 02-24-2006 08:17 AM
