making rough country lift ride smoother? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > making rough country lift ride smoother?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 02-12-2008, 08:55 PM   #1
snakester14
I have the rough country 4 inch series 2 lift. Its actually a decent lift for the money i paid for it but just a hell of a rough ride. To soften up the ride i was thinking maybe some OME or bilsten shocks. Will this be enough or do I need to get different coil springs as well?
thanks,
Jake
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline   Reply With Quote
Unread 02-12-2008, 09:19 PM   #2
snakester14
anyone? any recommendations on shocks?
Unread 02-12-2008, 09:25 PM   #3
CrunchTJ
After two years, the shocks that came with my RC Series II lift were shot. I replaced with with RE Monotubes, and the ride is much better. The RE Monotubes are still pretty stiff, so if you are looking for a softer ride, you might consider adjustables.
[b]'97 TJ[/b]: 2.5L, 4" Lift, 1" BL, 1" MML, 35's, 4.88's, Locker & Trutrac, Snorkel, Winch, Rockers, Snorkel, etc...
[b]'06 XK[/b]: Limited HEMI 4x4 with QDII - DD
[url]www.cypressoffroad.com[/url]
CrunchTJ is offline   Reply With Quote
Unread 02-12-2008, 09:49 PM   #4
dr_finklestein
thanks,
Jake
Springs really don't ride rough, shocks do. I have 4.5" springs and I replaced my DT3000 shocks with OME and instantly noticed a difference.
2004 TJ
3.5 RE Superflex
SYE & Denny's CV DS
Bushwacker pocket flares
[COLOR="Yellow"]Yellow Jeep Clup Member #1099[/COLOR]
dr_finklestein is offline   Reply With Quote
Unread 02-13-2008, 06:05 AM   #5
M2LJ
Yeah, the DT3Ks are kinda harsh, aren't they?
Cheers! M2
M2LJ is offline   Reply With Quote
Unread 02-13-2008, 07:20 AM   #6
chutta
Every year, 4wd hardware has a 4 for 3 sale on skyjacker hydros. I am waiting for that
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline   Reply With Quote
Unread 02-13-2008, 09:02 AM   #7
1CleanTJ
change out the shocks and adjust your tire pressure, should help a bit
1CleanTJ is offline   Reply With Quote
Unread 02-13-2008, 04:36 PM   #8
BlueFlame
Here's how to make that RC lift ride better.
1. Remove the lower front forward control arm bolt. Set that aside.
2. Remove the rest of the springs, control arms, track bars, steering damper and shocks.
3. Replace it all with a RE 4.5 system, and your choice of OME, RE monotubes, or Bilsteins.
4. Remember the bolt? You don't need it.
Just kidding.
Shocks are what you need.
BlueFlame is offline   Reply With Quote
Unread 02-13-2008, 06:35 PM   #9
ZJrebel
I have the same lift and had the same problem. All I did was disconnect the sway bar and it rides alot better.
ZJrebel is offline   Reply With Quote
Unread 02-13-2008, 06:51 PM   #10
warcloudwells
Jeez, who engineers some of these products? I just installed today the Superlift 2-inch BB (kit 5062) on my '06 and holy crap, it is extremely rough riding. I installed Rubi springs, which have higher rates, but it is these new superlift shocks (10-stage valving my arse), that have turned my pleasant DD TJ into a harsh, rough rider. Am I gay?. I hope they break in, or I may switch the whole thig bact to stock. by the way, I got 2.5 lift at the rear, and 2.0 at the front with 1.75-inch spacers and rubi springs.
warcloudwells is offline   Reply With Quote
Unread 02-13-2008, 07:16 PM   #11
BaddAndy
My RC kit rides alot better after I swapped the springs for Skyjackers and the shocks to OME
2001 Jeep TJ Sport, SOLD!
2013 JK Sport, 3.73s, 6 Speed manual, RC 3.5" Series II, GY DTs 315/70/17, Pro Comp 7005s 17x8
BaddAndy is offline   Reply With Quote
Unread 02-14-2008, 04:37 PM   #12
snakester14
I thought the DT3000s were supposed to be soft? I was looking into them b/c their half the price of OMEs. Anyone have any shock recommendations? How about some skyjacker hydros or full traction hydros? JUST LOOKING FOR A SOFTER RIDE.
thanks,
Jake
Unread 02-14-2008, 06:50 PM   #13
BaddAndy
thanks,
Jake
The DT3000s are. They ride a soft as my OMEs do
Unread 02-14-2008, 07:05 PM   #14
snakester14
I think im gonna get they skyjacker hydros I have only heard good things about them. I have heard to many mixed reviews about the DT3000s being real soft and real stiff. Im sure anything will be better than these rc8000s
Unread 02-16-2008, 02:43 PM   #15
ToyTJ
2008 WK
I've got the same RC 4" Series II and the same complaint. I ordered the OMEs today from Quadratec and I'll let you how they perform.
ToyTJ is offline   Reply With Quote
