Quantcast Making my own "raingler" nets - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Making my own "raingler" nets
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 03-10-2009, 11:24 AM   #46
IdahoTJ
Your nets look great! I've been working on (okay, so I only have strips of webbing cut so far -- I started last fall) a net for my trailer. Couldn't figure out how to keep the corners nice and square, I think those clips will do the trick! Thanks for the idea! As far as searing the end of webbing, if you have an old coil style stove (please don't do this on a glass top stove, your mom or SO will be verrry upset with you) you put it on high, touch the end to it, and you have successfully kept the end from fraying. I learned this back when I used to do a lot of climbing to seal ropes, webbing, etc. House needs to be well ventilated, it will stink, but it will burn off the coil style burner on high. Doesn't work with cotton webbing, but I think that is obvious.
IdahoTJ is offline   Reply With Quote
Old 03-10-2009, 05:40 PM   #47
ImaginaryFriend
ImaginaryFriend's Avatar
Great work!
You can use a high wattage soldering iron to seal off those ends too.
ImaginaryFriend is offline   Reply With Quote
Old 03-10-2009, 08:32 PM   #48
boardsurfer
Those look fantastic! I will consider this when I take the dog out with me.
boardsurfer is offline   Reply With Quote
Old 03-11-2009, 09:50 PM   #49
Krittergetter
There is a perfectly good way to deal with the "FRAYING" ends. Like the OP and others here, I too was planning the big day of Sewing mine together. I seached it out well! I did find a little machine that "BURNS/CUTS" the webbing. It was cheap like $60 and that was when I stopped. Yah what am I going to do with it afterwards? NOW! Id sell it to the next guy!!! I just dont have time guys...So one of you go 4 it. Just search webbing, Web strap cutters? Have fun. And dont forget the pics!!!
When they ask "How are you doing?" I just grin and say... "WELL, IM UPRIGHT AND SUCKING AIR!"
Krittergetter is offline   Reply With Quote
Old 03-12-2009, 12:20 AM   #50
JWitt333
ΜΟΛΩΝ ΛΑΒΕ
JWitt333's Avatar
looks great, if had a sewing machine i would make some
'99 Gunmetal TJ
Blue Jeep Club Member #256
4" RC X-Series, 1in BL
Rokmen Armor
KC Day Lighters, 33 BFG M/T
with more to come
OlllllllO
JWitt333 is online now   Reply With Quote
Old 03-12-2009, 04:43 AM   #51
dodger889
lost in the woods
dodger889's Avatar
You could buy one cheap for 20-40 used one. Make what you want then sell it will not cost anything but time....
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is online now   Reply With Quote
Old 03-12-2009, 07:19 AM   #52
tjsahara1979
I just borrowed my Mom's
I was able to work a little bit on the top last night. This week has just been crazy busy. I'll post some more pics tonight.
Originally Posted by Dave Barry
There is a very fine line between "hobby" and "mental illness"
'01 TJ Sahara. 3" BDS lift, 1" PA BL, 33x12.50x15 Nokian Vatiiva M/Ts, Durango steering box, soft 8s, RE steering stabilizer, and one LOUD effin' train horn :)
Green Jeep Club Member #183
tjsahara1979 is offline   Reply With Quote
Old 03-12-2009, 07:59 AM   #53
Dusty5150
hey thanks for the write up .. I'm planning on doing my own as well. Just trying to source the materials locally as ebay exchange/shipping is nuts to Canada right now .. havin a tough time though. any canucks have any ideas?
2000 TJ Sport w/ 31's on soft 8's, BDS 2" susp. lift, JKS discos, 10k winch
Dusty5150 is offline   Reply With Quote
Old 03-12-2009, 01:23 PM   #54
WVmountaineer
will definatly look into doing this, will get the melting cutter thing though, I also rock climb and use a LOT of webbing. It has so many different uses, I will definatly by far pay for itself. Nice write up thanks for the idea to make my own instead of buying it.
WVmountaineer is offline   Reply With Quote
Old 03-12-2009, 01:45 PM   #55
jdw999
That looks really good. Congrat's...
2005 Wrangler Rocky Mountain * Silver * 4" RC Lift * 4.0L * 33 x 12.50 x 15 on Black Steelies *
"Default Jeepers" #69
jdw999 is offline   Reply With Quote
Old 03-12-2009, 08:24 PM   #56
chorndawg
Originally Posted by tjsahara1979
"I ended up picking up 50 yards of 1" and 50 yards of 2" Heavy Duty Polypro webbing, 50 1" tension locks, and 50 2" welded steel rings for just under $50 shipped. I borrowed the sewing machine from who else, but Mom!"
Where did you use the 2" webbing? I was thinking you were going to use it on the edges, but it doesn't look like it in your pics. It does look great though. Thanks, for any info.
chorndawg is offline   Reply With Quote
Old 03-12-2009, 09:10 PM   #57
tjsahara1979
I'm using it on the top portion. Thanks for the positive comment!
I finished up the main portion of the top today. It takes a considerably longer time with the extra stitching for the o-rings. Came out even nicer than the windows so far!
Here are some pics. 56k killers! Dont mind the dog hair. They lay on them when I'm at work for some reason.
This is where I used the 2" webbing
Measuring everything over and over takes a while. I'm thinking of making a type of jig next time. It'll shorten that portion up.
My best friend throughout this process! A chip clip! Makes it easy when you're moving the area to be sewn back up to the table.
All the o-rings sewn in. Tomorrow or this weekend I'll be finishing it up.
Old 03-12-2009, 09:16 PM   #58
RubiExpressTJ
$120 plus a pop? Man i should talk to the guys at work into making these.
- Luke
RubiExpressTJ is offline   Reply With Quote
Old 03-12-2009, 09:26 PM   #59
benjamin.olejnik
Yea they are big bucks! These look great, I am inspired. And I know how to sew, long story....
benjamin.olejnik is offline   Reply With Quote
Old 03-12-2009, 09:34 PM   #60
mxracer513
I'm also quite inspired!
My Dually CJ Restoration http://www.jeepforum.com/forum/f8/cj5-restoration-thread-632654/
../|,[____],
.i.---L-[]IIII[]-
()_) ()_)-o-)_)
KB3RDF ..... Yellow Jeep Club Member # 513
mxracer513 is offline   Reply With Quote
Glock Forum
